how to do high idle on manual tranny
Old Dec 13, 2009 | 06:28 PM
rattlbox's Avatar
Does anyone know were to get the directions on what needs done to get high idle to work on manual tranny trucks...thanks in advance for the help
Old Dec 13, 2009 | 06:44 PM
RollOver Pete's Avatar
If I remember correctly, ground the #32 pin from the ECM and have the high idle enabled. This will make the ECM think you are powering a PTO. The cruise control is used to set the RPM's.
Old Dec 13, 2009 | 06:47 PM
billie's Avatar
All I've read says you can't do it on an 03, is that right? I would like to have it.
Old Dec 13, 2009 | 06:50 PM
tryNto's Avatar
Try looking here...
I've read it may work on the late '03, my mfg. date is 5/03, so I am going to try...
Old Dec 13, 2009 | 07:18 PM
Correction...
Ground the #22 pin.
If you go to a Cummins parts house, ask for an ECM pin repair kit. They don't cost much and will give you the correct pin with wire attached that you ground to one of the bolts holding the ECM to the engine block. It's simple and only takes a few minutes to do. When you back off the two plug screws, pull the plug holding the harness, locate #22 and shove a paper clip through it. A orange colored plug will come out.You then insert the repair pin in its place, plug in the harness, tighten down the two screws and ground the new wire. With the parking brake on, truck running, trans in neutral, foot off of the clutch and brake. Turn on the cruise control button then hit set. RPM's should climb. If they dont, you need to enable the PTO/ high idle function.
It worked on my 06
Old Dec 13, 2009 | 07:25 PM
rattlbox's Avatar
i have a smarty so it should already have enabled high idle correct?
Old Dec 13, 2009 | 07:29 PM
Only one way to find out...
Is the 22 pin grounded yet?
Old Dec 13, 2009 | 07:37 PM
Here is the pin and part# I used.
Old Dec 13, 2009 | 08:44 PM
rattlbox's Avatar
no not yet gotta get the wire repair piece....lol......gettin my ducks in a row
Old Dec 13, 2009 | 10:01 PM
OK.
Its an easy mod. Ya might want to disconnect your batts when plugging in the ECM just to be on the safe side?
Old Dec 13, 2009 | 10:19 PM
rattlbox's Avatar
k thanks for the heads up
Old Dec 13, 2009 | 10:46 PM
NickBeek's Avatar
I'll add one more correction to the above. There are 2 plugs that go into the ecm. A in front, B in rear. You want pin #22 plug B. It works great for warming up as well as to help the A/C stay cool in the summer.
kicker210
Dec 2, 2009 08:23 AM
hivoltage
Nov 21, 2008 08:37 AM
jmccart
Jun 12, 2007 02:12 PM
ezdemon72
14
Jul 29, 2005 10:05 AM
Patrick Campbell
17
Dec 2, 2003 08:03 AM
