why is the keyway specific to pump #?
Old Aug 23, 2006 | 09:19 PM
TNutcher's Avatar
I just got a new VP44 and well the keyway got damaged so I needed to order a new keyway. My old pump is an 0-4-5 and my new one is an 0-4-4. Is there a difference that would define why I cant swap the keyways??? They look EXACTLY the same size/shape.... anyone with insite please help. Thanks,
TNutcher
Old Aug 24, 2006 | 12:00 AM
jrs_dodge_diesel's Avatar
Where did you read where you couldn't swap keyways?
Old Aug 24, 2006 | 09:07 AM
Bart Timothy's Avatar
For optimal performance you will need the correct keyway.
Old Aug 24, 2006 | 09:29 AM
TNutcher's Avatar
The fellow at the shop I got the pump from said that the keyway's were matched to the pumps and affected the timing (I think timing). How can a little piece of metal do that??? I don't get it... lol but yeah I'll probably wait for the correct one thanks,
TNutcher
Old Aug 24, 2006 | 11:21 AM
zukgod1's Avatar
I'm not positive but I think it has to do with the pump being calibrated with that key in place, I cant imagine a different key making that much or a difference but I dont rebuild VP's either.
BTW, they told me the same thing when I replaced my VP as well.
dan
Old Aug 24, 2006 | 02:11 PM
mgstroker95's Avatar
I say if they are identical and they are the same thickness I would use the old one but thats me. I understand the concept but there is no way that they are hand making every key way that goes in every VP. Maybe I am wrong but it doesnt seem logical. Good luck bro
Old Aug 24, 2006 | 04:08 PM
nitrousn's Avatar
You dont understand the concept thats the problem. The key is matched to the pump. The key only goes one way on the pump it is offset.. The thickness of the keys are the same it is the offset thats critical.
Old Aug 24, 2006 | 05:51 PM
gmctd's Avatar
The slot in the shaft and the slot in the gear are the keyways - the piece of steel with the offset is the timing key................
Old Aug 24, 2006 | 07:59 PM
GrampZ's Avatar
10-4, I don't even know about this issue but I was going to add that there is a diff. between the "keyway" and the "key".
Old Aug 25, 2006 | 12:26 AM
TNutcher's Avatar
thanks guys. Yeah I got the key *not keyway*(Haha thanks guys! ) and just put it in more carefully this time and it was not a problem. Idk on something thats kind of envolved a job like this somewhat is, I'd rather not have to re-do it so I waited. But the truck runs good so far, as it should anyway... still a little slow haha. But Thanks for your advice! Appreciate it! Haha,
TNutcher
ClassA4x4
Apr 11, 2013 09:36 AM
BlackRam1
Mar 12, 2009 11:40 PM
sgrooms
21
Apr 8, 2008 11:17 AM
guhfluh
Oct 23, 2006 08:13 AM
baffled
May 4, 2006 11:02 PM
