Dana 70 hub nut keyway?
Old Oct 22, 2006 | 03:49 PM
guhfluh's Avatar
I have a '96 2500, CTD, Auto, 3.55 gears and what I believe is a Dana 70(The option codes are no longer under the hood from a previous wreck and hood replacement.) I have a hub seal leaking, and after removing the axle I am trying to remove the hub nut, but it has what looks to be a keyway made of thin metal preventing the removal of the nut.
How do I remove this?
I have tried removing it by pulling with pliers and cannot get it to budge. I don't want to try and remove the nut and mess up the nut or threads on the housing.
Old Oct 22, 2006 | 04:02 PM
infidel's Avatar
The lock wedge pulls out with just pliers but is usually not reusable. A pair of them from the autoparts costs about a buck. If they can't run down the number according your Dodge specs the same lock wedge is also used on Fords.
Old Oct 23, 2006 | 08:13 AM
guhfluh's Avatar
Thank you. I have removed it with a pair of small vice-grips and tapping with a hammer.
mr_ed
Feb 8, 2009 04:16 PM
Rafter B
Jan 11, 2009 08:40 PM
Crimedog
Feb 27, 2007 10:39 PM
TNutcher
Aug 25, 2006 12:26 AM
baffled
May 4, 2006 11:02 PM
