VP-44 keyway number????
Old May 3, 2006 | 03:16 PM
baffled's Avatar
I have 2 VP-44 injection pumps. I know that one of them has a bad electronic module and the other one has internal damage. I want to take the module off the damaged pump and swap it with the other one. One of them uses a .035 Key and the other uses a .036 key.
Does anyone know if the number on the front key is matched to the pump or the electronics?
Old May 3, 2006 | 04:00 PM
BigBlue's Avatar
If I'm correct you can't switch the keyways.
Old May 3, 2006 | 04:56 PM
nitrousn's Avatar
The key is matched to the internal workings of the pump. So you can swap the electronics but leave the keys with the pumps.
Old May 3, 2006 | 07:37 PM
baffled's Avatar
Thank you for the info. That's what I thought, but I wanted to make certain before installing it and maybe having to take it off again.
Old May 3, 2006 | 11:46 PM
PourinDiesel's Avatar
Those keys should be really close to each other in offset so I bet either one would work in either pump and you probably wouldnt notice.
Old May 4, 2006 | 11:02 PM
Sixpack's Avatar
We did it and there was not a problem. I'd say if the #'s are pretty close you probably won't have a problem.
ClassA4x4
Apr 11, 2013 09:36 AM
BlackRam1
Mar 12, 2009 11:40 PM
guhfluh
Oct 23, 2006 08:13 AM
TNutcher
Aug 25, 2006 12:26 AM
Bushy
Jul 16, 2005 01:50 PM
