Tranny Fluid for NV5600
Old Aug 3, 2003 | 04:36 PM
Dr. Evil's Avatar
A couple of questions guys, if you dont mind...
Looking at changing transmission fluid in my 6 speed....what are the rest of you guys using? Ive got just over 40k miles - I know that the manual does not specify that its due for a change but Id like to change it anyway. I would like to go with synthetic (Is the factory fluid synthetic??)
I assume you drain it through the PTO port?? Thanks guys.
Old Aug 3, 2003 | 06:36 PM
Re:Tranny Fluid for NV5600
I have Redline MTL in my truck, and it did make a big difference in the way the truck shifts. The shifter doesn't hang up going into gear, it just slides in. It was worth every penny of the 7 bucks a quart. BTW, my '93 FSM specifies 36k as the interval on the NV4500, but says the Getrag is set for life. Guess they didn't expect it to last long...
Old Aug 3, 2003 | 09:08 PM
HeberRam's Avatar
I have changed to Redline MTL as well...Have had no problem, and like "wannadiesel" said did work much better. The correct amount to put in is 9.5 pints, however, its very difficult as it starts burping out about at 8 pints through the fill hole. No problem, just fill the balance through the top by removing the top bolt on the PTO cover and pump it in. I put in all 10 pints.
Steve
Old Aug 4, 2003 | 09:46 AM
OlBlue's Avatar
Redline MTL here also.
Old Aug 4, 2003 | 11:31 AM
Dr. Evil's Avatar
Thanks guys....looks like RedLine is the way to go. Hopefully I can find it up here.
Old Aug 4, 2003 | 05:03 PM
TomGolden's Avatar
I use Amsoil series 3000 5W-30 engine oil in my NV5600.
I also have FastCoolers on my 6 speed. Mine didn't have any shifting problems before I went to synthetic, and it hasn't had any since making that change.
Tom
Old Aug 4, 2003 | 07:14 PM
Dr. Evil's Avatar
I assume the filler plug is on the passenger side infront of the reverse switch. Looks like would be hard to fill.
Old Aug 4, 2003 | 10:11 PM
Dr. Evil's Avatar
At the risk of sounding stupid - Is there no dipstick?? (other than me that is....)??
Old Aug 4, 2003 | 10:25 PM
BigK's Avatar
Strongly echo TomGolden's post.
Works for me.
Amsoil everywhere.
For the last 18+ years in everything I've owned.
Never sold a drop of it for profit, either.
To each, their own.
Lotsa good synthetics out there.
Old Apr 1, 2017 | 02:54 PM
dustinbabin's Avatar
That's a big negative
billie
ABDTR #5
17
Feb 8, 2009 11:48 AM
drafalske
Jun 15, 2003 01:55 PM
K2Cummins
Jun 6, 2003 12:18 AM
MikeyB
Apr 12, 2003 12:31 PM
