Alternative fluid for NV5600
Old Jun 10, 2003 | 01:54 PM
drafalske's Avatar
OK, I'm sure this has been gone over before but I can't seem to find it on the searches... maybe not going back far enough. My truck has just over 30k on it, and the tranny fluid still looks/smells new. Thats pretty cool. <br>But I don;t like it...<br>I know the all-knowing owners manual says that the NV5600 is &quot;permanently lubricated and does not require regular fluid changes as part of routine maintenance&quot;<br> <br>Am I way off kilter here? I can't see leaving the same ole tranny fluid in there for the life of the truck. I gotta get it changed, this is driving me crazy. On to my question.<br>What are you other 6sp owners using as an alternative to the Mopar oil for this thing (the ONLY recommended lubricant &gt;)? <br>-Dave
Old Jun 10, 2003 | 09:35 PM
Ole Blue's Avatar
Re:Alternative fluid for NV5600
I put Royal Purple in mine 5k ago and it works great.....Blue
Old Jun 10, 2003 | 11:27 PM
owtlaw's Avatar
What about redline MTL? has any one used it in their 6 sp? What about the transfer case?<br><br>Jason
Old Jun 11, 2003 | 07:17 AM
drafalske's Avatar
Blue, what viscosity Royal Purple are you running in your tranny. I think I'm gonna with that. How many quarts does it hold?-D
Old Jun 11, 2003 | 12:28 PM
Ole Blue's Avatar
I used RP Syncromax ,it takes 5qts......Blue<br><br><br><br><br>
Old Jun 12, 2003 | 12:24 AM
HC's Avatar
HC
&quot;Good for the life of the truck&quot;. Easy for them to say; they replace it if it goes out in the first 100k (life of the truck drivetrain warranty), but after that it's you who'll pay the bill.
I'm having the factory lube changed out about every 30 to 50k with the Mopar stuff. Some others report good results with the 5W-30 Series 3000 Amsoil (motor oil), but when you look at the cost of the better synthetics (Amsoil, Royal Purple, etc.) you don't save that much compared to using the Mopar. If you're still under warranty, go Mopar. My 2 cents.
Take note, the NV5600 is MUCH closer to motor oil than to gear oil. If you go with anything other than Mopar, make sure the selection is right; don't go just by what we're saying here on the internet. You're betting your transmission that we're right.
Old Jun 12, 2003 | 08:32 AM
HOHN's Avatar
I use Redline MTL with excellent results. Not cheap, but show me something of extremely high quality that is..<br><br>HOHN
Old Jun 13, 2003 | 12:40 AM
Ruralmedic's Avatar
Whoa, before dumping a motor oil in your transmission, realize that the additive chemistry is much different for a gear lube. I wouldn't recommend a motor oil in a transmission, even if big &quot;A&quot; says it's OK.<br><br>Most manual transmission's spec a GL-4 rated lube. Most of the synthetic gear lubes you will find are rated GL-5, which are for use in hypoid gear axles. GL-4 lubes have different friction coeffiecients for the synchronizers of manual tranny's, and are more &quot;friendly&quot; to yellow metals.<br><br>I don't know about RP, but Redline MTL is rated GL-4. Redline is usually around $8 a quart, and sometimes you can find an online vendor of it that has free shipping.
Old Jun 14, 2003 | 10:21 AM
HC's Avatar
HC
[quote author=Ruralmedic link=board=4;threadid=15734;start=0#148864 date=1055482850]
[/quote]
Oops, looks like I need to clarify where I stand, cause actually we're in almost total agreement! Folks need to remember that we have different transmissions, and use those owner's manuals.
The NV-4500 does use GL-4. The NV-5600 does not.
On big &quot;A&quot; saying use their 5W-30 in the NV-5600, I agree completely about additives being key to long life, that's why I recommend staying with Mopar on this one. I absolutely do not put any faith in something just because someone says &quot;works for me&quot; but has less than say, 500,000 miles on the stuff. I have seen some that took lube samples after using big &quot;A&quot;; something like that is more convincing to me because it would show a problem long before the gears started humming or clashing, but I haven't seen enough data to switch yet.
What I was really trying to say is that the NV-5600, I believe, is not like &quot;most&quot; transmissions because it does not use the hypoid &quot;gear oils&quot;. Some Honda's, some Izuzus, and others really do use &quot;motor oil&quot; in their transmissions, and if you put in the GL-4 or GL-5 gear oils in one of these special transmissions because someone on the Internet recommended it, you might crater your transmission. I know several Izuzu owners who did exactly that. On the other hand just as Amsoil claims their 5W-30 will work, Redline claims their MTL will work in both the GL-4, 75W-80 applications AND in applications calling for 5W-30 motor oil. That's a new one on me; I'm still learning too. We need someone who knows the specs on the NV-5600 lube better than me to step in here, but as I understand it, the fluid for the NV-5600 is &quot;similar&quot; to &quot;motor oil&quot;, but with some very important additive packages. This allows big &quot;A&quot; to step in and say their top-of-the-line 5W-30 will work; but for me, on this one I'm sticking with the Mopar fluid because I'm not 100% convinced the 5W-30 is &quot;better&quot; and I don't want to gamble on the cost of a replacement tranny even 300k from now.
Bottom line: Use the recommended stuff from Mopar, or research VERY carefully!
Old Jun 14, 2003 | 02:19 PM
HC's Avatar
HC
Good point Gary. I've got &quot;A&quot; (15W-40) in the engine, and like it there, but it was not my intent to endorse it for the tranny - I was just mentioning it as something that some people do. At 134k warranty isn't an issue for me, but reaching 500k is.
Dr. Evil
Apr 1, 2017 02:54 PM
eswartz
Feb 23, 2005 01:19 AM
sshelly
Jul 17, 2003 06:36 AM
K2Cummins
Jun 6, 2003 12:18 AM
MikeyB
Apr 12, 2003 12:31 PM
