NV5600 tranny fluid
Old Apr 10, 2003 | 05:39 PM
MikeyB's Avatar
NV5600 tranny fluid
Anybody knows what type of fluid the 6spd uses? I'm thinking about replacing it with Redline MTL. Anyone tried this yet?<br><br>Thanks<br><br>MikeyB
Old Apr 10, 2003 | 10:07 PM
Nevada's Avatar
Re:NV5600 tranny fluid
Search the 24 valve engine/drivetrain forum and the &quot;other&quot; site, this is a popular topic and is as controversial and lengthy as any of your &quot;Why isn't Amsoil API certified?&quot;/&quot;Ford owns Cummins&quot;/&quot;How often should I change my oil?&quot; threads.<br><br>The only fluid other than the Mopar fluid (which by the way says on the bottle that it is specifically blended for the NV-3500 transmission) that STATES ON THE BOTTLE that it meets the Mopar MS-9224 specification is a Penzoil product that has been seen at Auto Zone. If you poke around in an old enough thread you will also see references to a Texaco product that is no longer made.<br><br>That said, if you search the threads you will find folks are using products from Amsoil, Redline, Royal Purple and everything from gear lube to 5W-30 motor oil. Apparently there are issues with the metal used in the sychros that can be deteriorated by the wrong fluid, and the fluids that are best for shifter &quot;feel&quot; are not necessarily good for the synchros.<br><br>To make a long story longer I am in no way qualified to render an opinion on your specific question. I am satisfied with the factory fluid in mine (although it took 20 ounces to top it off after I received the truck) I do not have the notchy shifting or the third gear grind that I have read about. Look around, there are a lot of opinions out there.<br><br>Good luck.
Old Apr 11, 2003 | 08:07 AM
bulabula's Avatar
The Ford guys at the diesel stop are asking the same ???'s for the ZF6.<br><br>Here's my non-answer comment. I've spent a fair amount of time draining fluids out of my cars and truck transmissions (syn, dino, oil, fluid), But; after spending $30+K on a brand new vehicle inside the warranty window, I'm gonna stick with the OEM recommendations (found in the Owners Manual). I have some of those aforementioned oils/fluids in my car and boat - and I like them. But the Blue Beast will follow OEM for now.<br><br>I'm an engineer, but not a ChemE; and even then wouldn't relish a grueling interrogation ordeal with DC Warranty folks if in fact something happened inside my tranny and I had decided to use an &quot;improved&quot; oil/fluid in proving my case. Can it be done? Sure. But my life is busy enough, why add an unnecessary variable?
Old Apr 11, 2003 | 10:06 AM
Ruralmedic's Avatar
It's my understanding the factory fluid in the NV5600 is &quot;fill for life.&quot; However, as we know, that isn't necessarily the case in the real world, as things can happen.<br><br>Red Line MTL would be an excellant choice. It's a GL-4 rated lube. GL-4 usually contains about 1/2 the sulfur/phosphorus anti-wear content of a GL-5 lube. Sulfur has been known to attack yellow metals, ie synchros, at high temperatures. Some claim this isn't an issue with a synthetic lube as they tend to run cooler. GL-4 will also provide better &quot;traction&quot; for the synchros. <br><br>Most other gear lubes I've researched are rated GL-5. I know Mobil 1 specifically states not to use their GL-5 synthetic gear lube in transmissions calling for a GL-4 lube.
Old Apr 11, 2003 | 11:22 AM
Badunit's Avatar
The 6-spd doesn't use heavy weight gear oil. It uses something similar in consistency to motor oil. GL-4 and GL-5 are gear oil specs, are they not?
Old Apr 12, 2003 | 12:31 PM
Ruralmedic's Avatar
Red Line MTL is a lightweight GL-4 gear oil. It says to have low temperature shiftability equal to an ATF and will not thin out at high temperatures. ATF atypically is a 20W oil. The higher synchronizer coefficient of friction of MTL allows faster upshifting and downshifting, and is non-corrosive to synchros and bushings.<br><br>MT 90 is their heavier transmission oil, which is a 75W-90 GL-4 lube. That would be indicated for the NV4500 5 speed transmission.
Dr. Evil
Apr 1, 2017 02:54 PM
billie
ABDTR #5
17
Feb 8, 2009 11:48 AM
drafalske
Jun 15, 2003 01:55 PM
K2Cummins
Jun 6, 2003 12:18 AM
