NV5600 tranny fluid in Calgary?
Old Jan 29, 2009 | 06:16 PM
billie's Avatar
I'm not having much luck finding manual tranny oil here in Calgary. What oil are you guys using and where can I get it? NV5600.
Cya & TKS
Old Jan 29, 2009 | 06:21 PM
ccmckee's Avatar
If i recall correctly that is a dealer only item or an amsoil equivalent and it's not cheap.
Old Jan 29, 2009 | 06:25 PM
billie's Avatar
I know the dealers but just don't like to go there
Where can you buy Amsoil up here?
Cya
Old Jan 29, 2009 | 10:15 PM
1-5-3-6-2-4's Avatar
you can use any old GL-5 rated oil the the nv5600. its the NV4500 that requires GL-4 rated oil for the synchronizer assembly.
Old Jan 30, 2009 | 12:28 AM
StealthDiesel's Avatar
Cya & TKS
Redline MTL from Mopac in my NV5600. ....Joe.
Old Jan 30, 2009 | 07:55 AM
billie's Avatar
Mopac! Thanks Joe. Totally forgot about them.
153624, you're kidding right?
Cya
Old Jan 30, 2009 | 08:56 AM
ccmckee's Avatar
No he's not, i knew it was one or the other that needed it.
Old Jan 30, 2009 | 12:16 PM
Lil Dog's Avatar
"Firing Order' is bang on.. The NV4500 is more sensitive to proper fluid grade, the 5600 not so much..
Old Jan 30, 2009 | 11:10 PM
DODGER BOMBER's Avatar
i got mine from Par Auto parts in Airdrie. Cost i think 16/L. But still cheaper than the dealer for the last time i changed mine. The dealer was 28/L IIRC.
Old Jan 30, 2009 | 11:37 PM
torquefan's Avatar
I always just use the Dodge stuff in NV5600s. Part # 4874464. Never experimented with anything else.
Old Jan 31, 2009 | 12:17 AM
cLAYH's Avatar
"Synchromesh" fluid is what you are looking for. Quaker State and Penzoil both sell versions of it.
I picked up some Quaker State today at NAPA for $12/L.
Old Feb 1, 2009 | 09:27 AM
billie's Avatar
Appreciate the feedback. I'll try and find some this week .
Cya
Old Feb 1, 2009 | 10:59 AM
cLAYH's Avatar
FYI I changed mine out yesterday. Drained it thru the bolt PTO cover bolt and then pulled the center console and shifter so I could fill it thru thetop. I put in 6L.
Didn't seem to make a difference. Still shifts like crap and hard to get into 2nd from a stop.
I guess I'll try the upgraded SB hydraulic kit. I'm thinking my stock system may not completly release the SB clutch.
Old Feb 1, 2009 | 11:01 AM
cLAYH's Avatar
FYI I changed mine out yesterday. Drained it thru the bolt PTO cover bolt and then pulled the center console and shifter so I could fill it thru the top. I did the overfill thing and put in 6L.
I guess I'll try the upgraded SB hydraulic kit. I'm thinking my stock system may not completely release the SB clutch.
Old Feb 6, 2009 | 08:35 PM
billie's Avatar
Well I found a few places and no one had the 7L i want. 1L here, 3L there, geez!
Anyway, I'm not in a hurry. I don't have any shift problems, just coming up on 160Km and figure its due
Thanks for the feedback.
Cya
