T-Case removal advice?!?!
Old Aug 14, 2007 | 10:11 PM
jmlcolorado's Avatar
Question T-Case removal advice?!?!
I'm geting ready to do the 5th gear fix this weekend. i dont have a trans jack to aid in the removal of the transfer case. How mush does this thing weigh? the truck isn't gonna be on a rack so it's an "on yer back" job for me. can it be removed by hand without damaging anything (output shaft in the tranny)?? i have a 3 1/2 ton floor jack but no tranny jack adapter for it
any advice would help alot.
thanks
Old Aug 14, 2007 | 10:15 PM
mini14's Avatar
http://dodgeram.org/tech/specs/tranfer_case.htm
Old Aug 14, 2007 | 10:18 PM
skynyrd's Avatar
the 241 transfer case is only like 60-75lbs the newer 271's are more like 100lbs but the transfer case isn't that bad to remove. just unbolt the drive shafts, unhook the linkage and vacuum hose. then it should be 6 nuts and pull it off.
Old Aug 14, 2007 | 10:19 PM
wow! that light?!?! i was expecting quite a bit more!!
THANKS FOR THE LINK!!!
Old Aug 14, 2007 | 10:33 PM
okay now how do i go about finding out what model t case i have installed on the truck?
98.5 24v 5 speed nv4500
Old Aug 14, 2007 | 10:35 PM
skynyrd's Avatar
the 271 is the third gen t-case the 241 is in the around the 2002 years so yours might be a 231 but when you pull it out there should be a metal plate on the t-case that has the information stamped in it.
Old Aug 14, 2007 | 10:44 PM
GREAT! thanks again for your help!
Old Aug 14, 2007 | 11:07 PM
skynyrd's Avatar
no problem glad i could help out.
HUNTINNUT
Jul 27, 2013 11:40 AM
wyododge
Aug 18, 2011 07:48 AM
dodgemaniac
Competition / Pulls / OffRoad
Jul 31, 2008 10:15 AM
trik396
Jun 1, 2008 07:04 PM
Charlie Hardin
Mar 8, 2005 09:59 AM
