i wanna pull!! ADVICE! ADVICE! ADVICE!
Old Jul 28, 2008 | 07:48 PM
dodgemaniac's Avatar
Lightbulb i wanna pull!! ADVICE! ADVICE! ADVICE!
the short version is i am thinking about building a pulling truck and need to know where to start?
okay now the long version and i apologize now. so i want to build a pulling truck and need to know where to start. right now i just have my truck in the sig and want to pull it but am not going to because i use it almost everyday to pull the gooseneck and cant afford to break it sled pulling.
i was thinking of buying a truck to use as a farm truck but mainly for pulling. i was thinkng that something like a 12v engine would be a good start. am i right in thinking something like a 1996 ex cab short bed dullie 4x4 would be a good vehicle? or what would be an ideal starting platform? im not planning on going crazy but just around 600hp or so...
would i be better off paying more for an original platform that that runs good and has a good body? or find something that is maby dinged up a bit or a blown engine and just have it built the way i wanted?
also what should i expect to pay to get to the point i want to be including buying a truck and building it up?
all advice comments thoughts appreeciated... let the posts roll
Old Jul 28, 2008 | 08:23 PM
SmokinDodge12V's Avatar
The truck you have would make an excellent puller.
Old Jul 28, 2008 | 11:30 PM
Diesel Doc's Avatar
12 valve manual trans 4.10 gears would be a good budget starting point.
Old Jul 29, 2008 | 12:56 AM
Kman9090's Avatar
Cheaper to build the motor then it is to do bodywork and build a motor. Unless you are going crazy and want a 3.0 truck and 1000hp then a vp truck pulls good with the right combination of parts.
Old Jul 29, 2008 | 06:42 AM
PourinDiesel's Avatar
What he says.
Old Jul 29, 2008 | 11:25 AM
so your saying it would be a better idea if i bought a good shape and good running truck and just at turbo injectors pump etc.. ?? and if so what would you suggest as a good starting platform? srw drw? reg cab, ex, longbed, shortbed? engine?
Old Jul 29, 2008 | 01:14 PM
Kman9090's Avatar
I said it would be cheaper to find a good platform good body and frame that doesn't have to be messed with. If it has a blown motor then you could go through it and do what you wanted to it but if it doesn't oh well. Friend has little over 6000 into his vp truck and he has been doing pretty good this year but he is at that vp's limit so he is going 12valve next year. Single rear wheel long bed is the key extended cab.
Old Jul 29, 2008 | 01:53 PM
sorry about the repete. thanks for all the info. i am new to any of this 21v stuff so im just learning.
should i be weary about builting up an engine that already has 1xx,xxx+ miles on? my cash flow is not unlimited and whatever i do i want to hold up for the most part.
Old Jul 30, 2008 | 04:34 PM
anyone??....
Old Jul 31, 2008 | 02:16 AM
Diesel Doc's Avatar
1xx,xxx is just breaking in for these engines.
Old Jul 31, 2008 | 08:12 AM
what about 15x,xxx or 2xx,xxx ?
Old Jul 31, 2008 | 08:37 AM
Diesel Doc's Avatar
I have seen well maintained engines with 300,000 that stil look new inside
Old Jul 31, 2008 | 10:15 AM
rollincoal02's Avatar
pretty paint doesnt win pulls.
buy smething older, spend less on initial costs, put the big money in the right parts.
find a 12v 5spd with 4.10 gears and a 241DHD transfer case.
big input and SBC dual disk clutch
traction bars
get a good 2.5" sized turbo
tweak your pump with a plate, rack plug, DV's, add some DDP3 injectors
have the head o-ringed and new valve springs, add studs
thats the jist of it. spend less on the truck, more on big power goodies.
markpr
Competition / Pulls / OffRoad
Apr 14, 2009 09:34 PM
TxDiesel007
Jan 7, 2006 04:02 PM
mytrucksaslug
Nov 2, 2004 07:02 AM
