Pyrometer Died
Old Apr 2, 2004 | 10:43 AM
RowJ's Avatar
Pyrometer Died
Was under hood near turbo and "nudged" Pyro probe by accident.
Now no readings at all! Anyone have this happen or know how diagnose problem?
Old Apr 2, 2004 | 01:00 PM
BigBlue's Avatar
Have you checked the connections to the wire? Not trying to insult you, but maybe one of the wires came undone.
Old Apr 2, 2004 | 02:37 PM
RowJ's Avatar
No offense taken
Everything on probe looks normal. Was short on time to get to meeting with customer so did not look closely. Will ck after work-just though someone might have been there & done that!
Update - Checked with Rod at Wildcat and Isspro. Apparently not unheard of occurance (when you mis treat it). I need a new probe.
Old Apr 6, 2004 | 09:33 PM
Huff nPuff's Avatar
The sensor is very easy to test.
Hook up a volt meter to the two leads at the sensor it should output a small voltage porpotionate to an increase in temperature.If it is outputting a voltage,the problem is in the wiring or the gauge.Hope this helps.Merv
Old Apr 7, 2004 | 12:27 PM
ramcummins's Avatar
Is this detramental if it is installed pre turbo (broken probe) or is it just a faulty probe
Old Apr 7, 2004 | 01:50 PM
RowJ's Avatar
Not detrimental at all-pre turbo is highly recommended by most members. My problem was pilot error; my hand slipped off a wrench and I slapped the probe fairly hard with my wrist. Going to change my user name to M.C. (for mechanically challanged).
Old Apr 7, 2004 | 06:56 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
That would be better than "limp wrist"
Man I hate when I do something like that, Ole Mr Murphy was working with you that day
Tommy93w350
20
Nov 1, 2005 11:07 PM
YinYaker
Jun 8, 2004 12:43 AM
Homestead
Feb 9, 2003 03:14 AM
adgr71
Jan 14, 2003 01:07 PM
Push Rod
Oct 22, 2002 10:04 PM
