Po216?
Old Jul 20, 2004 | 09:59 AM
MWomack's Avatar
Po216?
On the PO216 code could this be the fuel filter or something else other than
the VP44 going bad? I just want to check everything before I take it to the dealer.
I checked fuel pressure it’s not all that bad the truck has a bad stumble taking
off in low gear and will pick up at about 1800 RPM’s and more smoke than normal. From the search I really think it’s the VP44 but I don’t know a lots about these trucks. It's all stock.
Thanks
Old Jul 20, 2004 | 11:36 AM
dieselman24's Avatar
PUMP is bad timing failure...SORRY to here that...
Old Jul 20, 2004 | 03:31 PM
MOUSE's Avatar
The classic stumble and the dreaded 0216 code, sorry to hear that, replace the VP-44, fuel filter, and the lift pump, install a fuel pressure guage wish I could give you a better suggestion.
Old Jul 22, 2004 | 01:21 PM
MWomack's Avatar
Thanks
Just got a call from the dealer new VP44 & lift pump all covered all it's going to cost is for a fuel filter.
Old Jul 22, 2004 | 03:01 PM
dodgediesel4x4's Avatar
Save yourself a few bucks and do the fuel filter yourself. The dealer LOVES to screw people out of their hard earned $ (either $40 or $60 to do the change) for something that is so simple.
Old Jul 22, 2004 | 04:16 PM
MOUSE's Avatar
I agree save the money and do it yourself, however in this case if the dealer does it there is no question if there is a future warranty issue everything is documented.
Old Jul 27, 2004 | 12:45 PM
TE-44's Avatar
I just checked my truck for codes and 0216 showed up but truck runs fine no drop in mileage or power and no service light. Could this just be a false code due to the box I have installed or is this the real thing.
Old Jul 27, 2004 | 09:28 PM
J BODY's Avatar
Have them do the filter.
Old Jul 28, 2004 | 12:02 AM
Outlaw_Frog's Avatar
I also "hoped" that the fuel filter would do the trick with the code.. no such luck.. gave up the ghost a week later in an intersection on the way to work.. No indication.. was runnin fine except for an occasional dead throttle.. was purrin along.. stopped for a light.. coughed twice.. I said "oh Crap".. died.. no refire.. off to the dealer.. If yer gunna have to bite the bullet.. might as well get it before it gets you.. ie: leaves ya somewhere ya don't wanna be...
Good luck...
Jeff
64racing
Jun 26, 2007 09:06 AM
tswan
Mar 19, 2007 03:36 PM
tony3542
May 11, 2005 06:38 PM
bobo540
Dec 17, 2004 03:10 PM
DeereDiesel
Nov 2, 2004 09:26 AM
