wiring wastegate open?
Old Jul 27, 2004 | 11:00 AM
redhornet's Avatar
on a 2001 with 6-speed (HX-35?) how do I go about wiring the wastegate open?it has a "edge" 85hp chip so hopfully a boost fooler.thanx
Old Jul 27, 2004 | 12:41 PM
243's Avatar
243
Do a search for "turnbuckle" and you will find pics of the device...btw, you will be wiring it closed
Old Jul 27, 2004 | 12:44 PM
Mechanos's Avatar
Since you have an HX-35, just call Edge and have them send you a boost elbow.
Old Jul 27, 2004 | 12:47 PM
RustyJC's Avatar
Actually, the Edge EZ should have come with a boost elbow in the box. Maybe the owner still has it? And, yes, the EZ has a boost fooler function built in.
Rusty
Old Jul 27, 2004 | 04:55 PM
amartinson's Avatar
With your manual trans, you don't need to go the turnbuckle route. The boost elbow that should have come with the EZ will do the trick. As stated above, they would probably just send you one if you called them. Make sure to ask for install instructions. It's easy, but might as well do it right the first time.
Old Jul 28, 2004 | 05:27 AM
HOHN's Avatar
By the way, You want your WG CLOSED, not open.
With the WG open, the exhaust will bypass the turbine, and you'll have very slow spoolup, lots of lag, and lots of smoke.
justin
NorCal
Mar 6, 2009 10:27 AM
Desert Diesel
Mar 18, 2007 08:53 PM
bowtiestrkrsmkr
0
Nov 3, 2006 11:15 PM
j-dubya
Oct 23, 2005 03:25 PM
arroyojim
Oct 5, 2005 08:38 PM
