lift pump
Old Jan 22, 2007 | 10:59 AM
DeTree's Avatar
lift pump
ok....heres My question.....how long can the ip run with out the lift pump running?....will it toast it immediatly or????
Old Jan 22, 2007 | 12:19 PM
Marine's Avatar
Veteran: Marine Corp
It depends on the IP, but they will run without the LP. How long it will run is the issue.
Old Jan 22, 2007 | 03:38 PM
dieselbeef's Avatar
Muted User
about 1500$ worth of time. the ip dont suck fuel. park it unless yer rich
Old Jan 22, 2007 | 03:41 PM
AggieJustin's Avatar
The problem isn't so much that it won't run without the LP providing fuel (although sometimes it won't), but the LP provides excess fuel that is circulated through the IP for cooling. If the IP is just pulling the fuel it needs, you're running the IP hotter than it should and the electronics HATE heat.
Old Jan 22, 2007 | 11:49 PM
DeTree's Avatar
ok....but if it ran for 200 miles.....and there are no codes and everything seems fine......is it possible it is not damaged?
Old Jan 22, 2007 | 11:54 PM
Marine's Avatar
Hopefully it will be fine, but don't worry about that now. I would get a new LP on there pronto if the old one is bad!
Old Jan 22, 2007 | 11:57 PM
DeTree's Avatar
already installed...like I said...she ran about 100-150kms with out the lift pump working.....but she seems like she is ok now...the ip I mean. The ip was replaced by DC 2 months ago so I hope I didn't damage it
Old Jan 22, 2007 | 11:58 PM
Marine's Avatar
How much longer is it under warranty?
Old Jan 23, 2007 | 12:01 AM
DeTree's Avatar
another 4 months
Old Jan 23, 2007 | 12:11 AM
Marine's Avatar
I think you'll be fine. If it was going to crap out, it would have crapped out already.
Old Jan 23, 2007 | 12:18 AM
DeTree's Avatar
thx man......have a great nite...
Old Jan 23, 2007 | 12:21 AM
Marine's Avatar
You bet!
Thanks.
Old Jan 23, 2007 | 02:27 PM
ironbutt's Avatar
Detree; Your profile says more to come, do your self a big favor and get a fuel pressure gauge as soon as posible.
You might have dodged the (P0216) bullet due to the cool temperatures that you have up north, but usually the VP44 doesn't last long with out at least 5 psi fuel pressure.
" Good luck"
Txwelder
Nov 26, 2025 01:53 AM
Txwelder
May 19, 2005 06:10 PM
Yukon Dodge
18
Jul 1, 2004 10:08 AM
Puke
May 22, 2003 12:18 AM
Haulin_in_Dixie
47
Nov 17, 2002 09:30 PM
