HELP- Lift Pump problems, I think
Old Feb 24, 2006 | 03:16 PM
keithp777's Avatar
Here's the deal- I can start me truck no problem if it sits overnight, or for more than an hour. If it sits for 10 minutes or so, I have to crank crank crank- It sounds like the lift pump is running, but it still does nothing. Just installed a new fuel filter, but it still does it. Is there or is there not a pump in the tank? I have 3 different answers from 3 different people at the dealer-
Yes
No
uhhmm
I think they should all go with uhhmmm, myself. Any ideas??
Is there a pressure sensor somewhere that may be the culprit?
Thanks for the help!
Old Feb 24, 2006 | 03:27 PM
phox_mulder's Avatar
No, there is no pump in the tank in a 1999,
unless you've recently (in the last 6 months or so) had the lift pump replaced at the Dealership.
Sounds like a heat problem with the VP44 (injection pump, $$$).
phox
Old Feb 24, 2006 | 03:38 PM
keithp777's Avatar
Unhappy
It sounds like the lift pump only runs occasionally. If I crank for a bit & it wont start, sometimes it will run. Others, it does nothing.
Is there any way to tell if it's the VP44? ouch. I didn't want to hear that one...
Also, if I keep the tank @ 1/2 full or better, it seems to work much better.
Old Feb 24, 2006 | 03:41 PM
You could try getting the codes read, you'll need a scanner,
most likely the one that only Dodge Dealers have.
Bad VP44's don't always throw codes though.
phox
Old Feb 24, 2006 | 03:43 PM
keithp777's Avatar
It gives me no codes. I have a scanner, and it says nothing is wrong.
Old Feb 24, 2006 | 03:44 PM
Geico266's Avatar
Welcome to DTR
Good advice above. Without a fuel pressure guage you have no idea if your LP is working or not. It can be "running" and not pumping anything.
Old Feb 24, 2006 | 03:48 PM
keithp777's Avatar
It is pumping a good deal. I had someone else turn the key, and when it started, I opened the drain. It shot out at high pressure. You're right, I do need a pressure gauge. How hard is the install on the 99 Geico266?
Old Feb 24, 2006 | 10:33 PM
Dr. Evil's Avatar
Dead Easy - the pressure sample point is off the fuel filter. Have a look at Shovelhead or Rattliram's pics...they both have pics of the fuel pressure hook up on a 99.
Old Feb 25, 2006 | 12:12 AM
Barry St John's Avatar
Don't want to be the bearer of bad news but my last vp44 did the same thing. No codes that would show up but Dodge replaced it under warranty and it solved the problem. Good Luck!!
Old Feb 25, 2006 | 05:46 AM
99 cummins's Avatar
You may have a bad lift pump, but you also have a bad Injector pump to. That's a bet. What a way to start your day. By the way, welcome to your new home.
Old Feb 25, 2006 | 09:38 AM
keithp777's Avatar
Well, it does have 183,000 on the original VP44, using a lubricant at least every other tank, running 10-20% biodiesel. Can't complain THAT much. I think I'll milk it. It has been doing this off & on for 6 months, just really acted strange the other day, and seems to be a little better today & yesterday. We'll see.
For the better news, I have a supplier here in Houston that rebuilds these for 2 of the school districts I work with for $850, and they swear they last twice as long as the originals. If I can get the info I'll post it here. I'm sure it will be a little more than $850 as they have a contract with the districts, but...
Old Feb 25, 2006 | 12:14 PM
99 cummins's Avatar
I milked mine for quit a while, carried a cooler in the back seat full of bottles of cold water. When I went somewhere and had to shut it off, I just pulled out the water to cool it off enough to start. When it was running it would run all day so I didn't worry about it. I'm a poor man, took me a while to get together that kind a money and I don't use credit.
Old Feb 25, 2006 | 01:20 PM
snpr308's Avatar
Grrrrrr
Milking it could be a bad idea. Im looking at replacing my ignition pump after my second lift pump went. Spending the money on the LP beats the hell out of $1000 + for just a ignition pump
Old Feb 25, 2006 | 07:12 PM
keithp777's Avatar
No, this is not the lift pump we're talking about. I think I've ruled out the lift pump at this point. It is the injector pump, I'm afraid.
Old Feb 25, 2006 | 07:18 PM
99 cummins's Avatar
I think you misunderstood my post, I was talking about cooling the Injector pump with water. I am assuming this is what you mean by the ignition pump.
Txwelder
Nov 26, 2025 01:53 AM
2fast
Feb 22, 2007 05:02 AM
k9judge188
Feb 9, 2006 07:42 PM
Txwelder
May 19, 2005 06:10 PM
bkay
Nov 7, 2003 10:03 AM
