GM rear brake cylinder mod
I am planning on swithing my rear wheel cylinders on Sunday and I went under the truck today to spray some penatrating oil on the bolts and line,I noticed that the brake fluid feed lines are on a angle going into the backing plate.The GM cylinders I bought have a straight on inlet into the cylinder,I dont have it apart yet so I cant see the inner part of the backing plate,Just wondering do you have to modify the backing plate to use the GM cylinders.I got the Napa part# from a post in the search archives.Thanks and Happy New Year Everybody
GM Rear Cylinders
Tom,I was just wandering,the original cyl.hes the brake fluid line coming in from a angle and the GM cylinders have a straight in where the line would come in,I guess it would be no big deal to drill out the backing plate.
DRESSER DAVE
I did the swap also and on my 98 and the lines are straight in, the same as the Nappa cyls so sometime between 98 and 2000 they changed I guess? On mine the wheel cyl boss actually fits through the backing plate and the bleeder screw is on a angle. So your line shouldnt go thru the backing plate?
I did mine a few months ago and don't remember a big difference. Mine bolted up real quick and easy. If you want I can go crawl under and take a look and see if they are straight or angled.
I did mine and had to loosen the line bracket on the rear end housing to "adjust" the lines. other than that, a direct bolt in. The backing plate doesn't need to be modified. My truck being a 2001, is prolly the last run of rear drums, and I had no probs.
GM Rear Cylinders
Thanks Folks for the input,With the mud and dirt I could not really see how big the hole in the backing plate was,got them installed just waiting on my brother to come over and help bleed the brakes.Thanks Again
Re: GM Rear Cylinders
Originally posted by DRESSER DAVE
What a difference
What a difference
Gen414
05-07-2009 11:08 AM
cgmorgan06
11-15-2007 04:02 PM
Journier
11-22-2004 02:56 PM
