Running The Overhead
I just bought a 2001 Ram 24 valve and someone told me that after 100k miles to get the overhead ran. So, I took it to a diesel shop and got it done for $100.00. It doesn't seem to rattle as much but at the same time doesn't idle as well as it used to. Then about a week later I was reading in my Haynes manual that my particular truck adjusts itself and the overhead never needs to be ran. Whats everyones thoughts on this? Also, I watched the guy do it and to determine TDC he just turned the engine until the correct valve was up to its top point and not by pulling the timing cover as listed in my manual. I need some good direction.
all he did was adj. the valves right?!....most of us run them to the min. spec with good results...dose make it quiter and will give you more pwr.Its a cam timing thing if you think about it......loose you you got no juice,,too tight not right...
H8GAS
18
Aug 3, 2007 06:31 PM
RAM-RED
Feb 12, 2005 10:50 AM
