fuel leak at filter
Old Dec 1, 2006 | 12:46 PM
bfons's Avatar
fuel leak at filter
have a fuel leak at the 2 wires on the top of the fuel filter. can this be changed or need a new top?
Old Dec 1, 2006 | 07:00 PM
Clunk's Avatar
You might check to be sure you don't have 2 sealing rings in the top instead of the required single ring.
Old Dec 1, 2006 | 07:13 PM
bfons's Avatar
talking about the heater on the fuel filter
Old Dec 1, 2006 | 11:43 PM
Clunk's Avatar
What year?
Old Dec 2, 2006 | 10:27 AM
bfons's Avatar
Truck Is 99 3500 Ctd
Old Dec 2, 2006 | 02:00 PM
Clunk's Avatar
Mine looks like there's 2 torx screws holding mine on. Is there any holding yours on that could be maybe tightened up?
Old Dec 2, 2006 | 02:02 PM
jriggs_18's Avatar
After looking for the leak on my truck I too believe mine is leaking there, i just installed a walbro about 2 wks. ago and now it leaks, any fixes, mine has no screws holding it in
Old Dec 2, 2006 | 02:25 PM
Clunk's Avatar
Do you think maybe there's some screws on the inside? Anybody have a '98.5-'99 service manual?
Old Dec 2, 2006 | 03:28 PM
bfons's Avatar
3 screws under top. took mine off, removed screws and heater pushes out. small seal ring around black piece. looked ok but can't change, never get seal over plug. cleaned and used gray rtv silicon. waiting 2 cure. will update tommorrow.
Old Dec 4, 2006 | 10:44 AM
bfons's Avatar
had to bleed injectors. truck started up no leaks. hope this takes care of it.
Old Dec 4, 2006 | 11:57 AM
PChouinard's Avatar
I have the same leak around the fuel heater. Is this causing the vp to loose prime overnight?
dieselfuelonly
Jan 24, 2012 10:16 AM
RDMueller
Jan 25, 2011 07:14 PM
ZPOD
18
Sep 23, 2010 10:37 AM
Big Smoky
Mar 6, 2006 10:47 PM
steveb
Aug 20, 2004 12:48 AM
