Fuel Leak at Banjo Bolt on Fuel Filter Housing
Last night night I finally figured out where my MASSIVE fuel leak was coming from. It's on the banjo bolt that goes into the fuel filter from the LP. I couldn't find the exact washer with the rubber o-ring inside it so I used something similar except it was a little bigger but the o-ring fit snug around the bolt. I started it and it still drips pretty good. Are these washer/o-rings only availible at the Dodge house or the Cummins shop? The leak is so bad that on the back of my tail gate I have fuel splotches! My brother was driving behind me the other day and had to hang back because he was getting fuel all over his windsheild! Has anyone had problems with thes washers? Thanks in advance.
Eric
Eric
More often I've had problems with debris getting under the washer while the banjo is apart causing a leak. Sometimes this can damage the washer or seat and a new washer is necessary. Many times just wiping the debris off is enough.
Over-tightening a banjo doesn't really help it to seal any better and may make it worse, 18-20 ft/lbs is plenty.
Think you'll have a hard time finding the rings anywhere besides Cummins.
Oh, ok cool. I didn't know there was one there. We'll have to meet up sometimes. I wanna ride in your truck and see what that smarty and the ecm can do! I've been considering it.
Eric
Eric
Originally Posted by EGaskamp
Well, I think I got the leak fixed. Whats the best stuff to use to get diesel off of the frame and starter and all that stuff? Thanks
Eric
Eric
Eric
Eric
mpracehemi
Sep 21, 2008 04:35 AM
jmccart
15
Jan 26, 2008 09:32 PM
jmccart
Jan 26, 2008 07:36 PM
ptgarcia
Aug 18, 2006 03:52 PM
