Fuel Leak In Back Of Fuel Filter Canister
Old Aug 19, 2004 | 10:49 PM
steveb's Avatar
Have any of you had a problem with a fuel leak on the back side of the fuel filter housing?
I replaced my filter recently and now have a leak on the back side of the filter housing. While the engine is running its dripping diesel on my starter.
I pulled the $30 filter that I just repalced and found the rubber ring around the top to be loose. Bought another $30 fuel filter and just insatlled it but it's STILL leaking. Yes I replaced the rubber o-ring that goes around the stud.
$60 in filters and I'm at wits end unable to fix this leak.
Is there some other rubber seal that may be permanently mounted on the top of the filter housing that I lost or something???
Old Aug 19, 2004 | 11:13 PM
Smkndzl's Avatar
if all you did was change the filter , then remove cap and check the thread and make sure it was not cross threaded , which can happen easily on these ,
Old Aug 20, 2004 | 12:48 AM
Haulin_in_Dixie's Avatar
Possible thought, the older filters came with a seperate square rubber ring that went under the cover. The newer ones come with the rubber as part of the filter. Maybe you have an old ring still in the cover. Save the filter you took out, you can still use it, put it in a freezer bag to keep it clean.
jsmith2260
Apr 25, 2010 02:32 PM
dodge_24
Oct 1, 2009 05:33 PM
Spooler
22
May 6, 2009 06:50 AM
Wes in TN
Dec 30, 2005 11:01 AM
dodgediesel4x4
Sep 4, 2005 03:17 PM
