Track bar
Old 12-31-2017, 11:19 AM
cougar's Avatar
Track bar
Need one. My 01 is wandering around more and more. What would be the best replacement for a stock frame?
Old 01-01-2018, 06:30 AM
AlpineRAM's Avatar
I have good results with luke's links on the stock trackbar.
Old 01-01-2018, 03:05 PM
Busboy's Avatar
last fall we were checking the front end on my sons 2001 3500 which he had just been given by this Grandad. We knew that the truck had been neglected for some time but when we checked the track bar the front axle moved about 3 inches sideways, I couldn't believe it and wouldn't have without seeing it with my own eyes. A visual inspection of the track bar looked good and the truck drove ok even at highway speeds.
Old 01-02-2018, 03:20 PM
SIXSLUG's Avatar
I've got a Thuren on mine, great part, but won't fit all 01/02's without modification.
Geno's has a couple options.
Old 01-04-2018, 05:12 AM
2002-5.9's Avatar
I went with an XRF adjustable off ebay.
Old 01-05-2018, 12:54 PM
cougar's Avatar
Any advantage to doing the 3rd gen retro over a 2nd gen replacement?
Old 01-06-2018, 12:12 PM
Busboy's Avatar
The trac bar we installed was just a direct replacement second gen but it did say on the box that it has been manufactured in a way to address the problem of the one end wearing out so fast and also mentioned something about the material used. If I remember right it was a larger joint on that one end, it was nothing special just from the local parts store.
Old 01-07-2018, 11:11 AM
Received 2,392 Likes on 1,576 Posts
One my new back then '95 I bought a lifetime Moog one and just swapped it out every other year.
I ran 33X12.5 tires on 9.5 inch wide rims back then so it really was hard on those track bars.
I went through 6 or 7 track bars in about 14 years. I also run a lot of dirt backroads ups here.
Old 01-07-2018, 11:34 AM
SIXSLUG's Avatar
I considered it but Thuren had me check to see if a spray paint can cap would interfere with the differential cover hitting the mounting ring on the drivers side. It just missed so I didn't go with the 3rd gen conversion. But I have read a lot of guys that did were happy with it,,,just need a certified welder to attach the bracket and cut off the old one.
CTD2001
08-22-2009 10:03 PM
Dinner
05-29-2007 02:02 PM
kwillis-a
01-25-2007 09:10 PM
dieselgeek
03-19-2003 09:15 PM
MAX340
13
11-02-2002 07:47 PM
Quick Reply: Track bar
