Track Bar Advice needed
Old Mar 19, 2003 | 02:23 PM
dieselgeek's Avatar
Hi Everyone - no emergencies this time, the truck is at home... but approaching 200,000 miles, I just replaced a ball joint and the track bar is a little loose.<br><br>It has been very, very disappointing to find how &quot;unrebuildable&quot; the front ends are on these trucks. Mine's a 98 ISB NV4500 4X4... Anyways, I need advice on a track bar. No way in HELL am I paying $340 to replace the factory piece which will be bad again. I've heard a little about the DT trackbar - can any of you recommend this, or others? Cost isn't a huge problem - I just want to go with something more stout than what's under there. <br><br>Please advise if you have a second...<br><br>thanks in advance,<br>-'geek<br>
Old Mar 19, 2003 | 02:58 PM
boehunter49's Avatar
Re:Track Bar Advice needed
Hay check out this place http://www.lukeslink.com/ <br> I just got one an they save a lot of $$$$$$$$ an easy to use an they are ajustable if it starts to get loose again.<br> Bob
Old Mar 19, 2003 | 02:59 PM
KatDiesel's Avatar
DT is the best but exspensive.<br>There is also Lukes Link &quot;Repair&quot;<br><br>Napa has a lifetime warranty bar for around $140 or so? I've had one replaced under warramty from the dealer. Think its time to go get another one
Old Mar 19, 2003 | 03:52 PM
Dieseldude4x4's Avatar
I used the Lukes Link. Bout $79 for the link and the bushing. It's rebuildable and adjustable too.<br>
Old Mar 19, 2003 | 09:14 PM
mymaur's Avatar
I also used the Lukes LInk. You can talk to Luke on the phone. He guarantees satisfaction. I have had great luck with it. But, while it is definetly a job a home mechanic can do, it is not quite as easy as described in his literature to install.<br><br>I had to wrestle with it a bit, but once it's on, it definetly does what he says it will.<br><br>Good luck<br><br>gary
Old Mar 19, 2003 | 09:15 PM
John_P's Avatar
Like &quot;dieseldude4X4&quot;, I also have a &quot;Luke's Link&quot; on<br>my 96' Dodge CTD and am VERY happy with it!<br>It really helped tighten up the loose feel of the<br>track bar.<br><br>-------<br>John_P
CTD2001
Aug 22, 2009 10:03 PM
Dinner
May 29, 2007 02:02 PM
oldblues
Feb 25, 2007 09:39 PM
kwillis-a
Jan 25, 2007 09:10 PM
