Drive without Propshaft???
Gents,<br><br>I've had this rattle under my truck for some time and while I was crawling around under it tonight I think I may have found the culprit. The front driveshaft or propshaft u-joint where it meets the front diff is missing about half a cup off of it so that it slaps around in the yoke. <br><br>What I am wanting to know is can I drive the truck with the shaft off while I drop it (shaft) off for repair? Only 8 bolts total, 4 on diff and 4 on CV at t-case and its off. <br><br>Also, for the 5 spd guys, do ya'll have anything bolted across the bottom of the frame about 8-10 inches in front of the trans crossmember? I have 2 bolts dangling from inside the frame rail and the are signs (rust/paint vairations) of where there was something at one time. I do have the skidplate at the t-case but I don't know if there is something that is supposed to go underneeth the middle of the tranny. <br><br>Any help is always appreicated.<br><br>TIA,
Re:Drive without Propshaft???
I pulled my front driveshaft off chasing a vibration after I got my lift.<br><br>Drove around with it off for a week.<br><br>Only put it back on because I was going camping/wheeling and figured I'd better have 4 wheel drive.<br><br>Just mark everything so you put it back on the exact way it came off and you'll be fine.<br><br><br>phox
SSV1761982
Mar 16, 2012 12:43 PM
JaimeG
Mar 26, 2009 06:58 AM
Dieselnick
13
Feb 7, 2008 04:17 PM
SN162
Feb 8, 2007 07:13 PM
Copenhagenjunkie
Dec 27, 2002 05:45 PM
