Can I drive without the rear driveshaft?
Old Mar 11, 2012 | 04:04 PM
SSV1761982's Avatar
I need to take the rear drive shaft in to get it balanced. Will I lose my tranny lube if I drive without the driveshaft in the transfer case?
The truck is a 2002 6speed 4x4.
Old Mar 11, 2012 | 05:46 PM
Blueboy's Avatar
My truck is 05. It will leak if I pull drive shaft.
Old Mar 11, 2012 | 06:50 PM
Thundercraft's Avatar
It will leak
Last edited by Thundercraft; Mar 11, 2012 at 06:52 PM. Reason: rewrite for clarification
Old Mar 11, 2012 | 08:35 PM
Valv's Avatar
I had same issue with my Megacab.....you will not believe what an Intrepid can stow
Old Mar 11, 2012 | 09:41 PM
winkdemon's Avatar
you can drive the truck with no rear shaft but i would only drive it home or to a shop for repair , t-case will leak with the shaft out like above and is hard on the drivetrain . my 2 cent
Old Mar 12, 2012 | 07:53 AM
SSV1761982's Avatar
Thanks. I'll until I can use the wifes car to take the driveshaft off.
Old Mar 16, 2012 | 07:40 AM
nickg's Avatar
i drove my 03 without the rear shaft in to diagnoise drive line noise/vibration, i capped the output with an old paint spray can lid that fit tightly into the TC output seal, I then taped it in place with duct tape, likely drove 5-10miles at various speeds upto 50mph, never lost a drop....
that being said I kept an eagle eye on it for leaks
if you have a second car it would be the first choice
Old Mar 16, 2012 | 12:43 PM
SSV1761982's Avatar
Thanks. My wife had a day off so I used her car. Got the driveshaft balanced and still have some rumble coming from the rear of the truck. It ain't bad but it is still there. It was gone with the back half of the driveshaft off. Tired of messing with it.
boony
14
Jul 17, 2012 11:01 PM
Totallyrad
Jul 19, 2011 07:41 AM
Dave88LX
Jun 14, 2007 09:52 PM
05 CTD2500
May 13, 2007 08:55 PM
