Code question
Old Jul 31, 2008 | 07:48 PM
quads4_life's Avatar
Code question
Hey my buddy has an 2001 24v and it threw a code today it come up as
P1694
anybody know what this code is??
Old Aug 1, 2008 | 03:48 AM
Rattle This's Avatar
P1694
No CCD Messages Received From ECM
FOUND AT: http://www.thedieselgarage.com/forum...ad.php?t=25062
DO A SEARCH YOU CAN FIND ANYTHING.
HOPE THIS HELPS.
Old Aug 1, 2008 | 07:02 AM
it helps a little but not real sure what it means. I am not real good at understanding code language.
I am not sure what the CCD is
Old Aug 1, 2008 | 07:31 AM
Coagulation's Avatar
Muted User
OK here goes, the ECM in mounted to the side of the engine, it controlls the VP and other engine related things. It then recieves and transmits information to the PCM mounted on the firewall on the passenger side. They communicate through "A CCD data bus" When they dont communicate with each other for one reason or another you get a code. It is probably a wiring problem but it can also be an internal problem.
Old Aug 1, 2008 | 09:59 AM
sheriffav8r's Avatar
1693 and 1694 are usually companion codes meaning they aren't communicating on a specific task. They will usually reset after a specific number of engine cycles and may be set off if you flash your ECM program or do something with a chip. These codes are usually not important but just refer you to the other control unit (PCM or ECM). As long as there are no other codes, I would just clear them and see if something else shows up later....
Just my 1.8 cents (inflation sucks)....
coope3
Feb 21, 2009 04:49 PM
O.T
Sep 6, 2007 06:10 PM
Terraizer
Dec 14, 2005 03:56 PM
CTD NUT
Apr 5, 2005 04:45 PM
TEDHRS
Nov 9, 2002 12:35 AM
