1999 Dodge diesel starts then stall
Old Nov 15, 2010 | 09:59 AM
mr4732's Avatar
My 1999 Dodge cummins just started to do this. When first starting after a few days of inactivity the diesel starts then stalls out. it will start again after a few seconds of cranking and is ok after that. I have 135 k miles and the truck is in excellant condition. Changed fuel filter about 10k. Any Ideas?
Old Nov 15, 2010 | 10:58 AM
The_Head's Avatar
You posted in the wrong forum (1st generation, 89-93), but I think you could have air in your fuel system, or an air leak, after you swapped out fuel filters.
Old Nov 15, 2010 | 11:12 AM
rebal's Avatar
yup you got air coming in
Old Nov 16, 2010 | 11:01 AM
mr4732's Avatar
Thanks for the info... now for a real stupid question. where do you start looking? Fuel tank? Filter? Injectors?
Thanks for any info.
Happy trail
Old Nov 16, 2010 | 04:01 PM
dkenny's Avatar
ditto on the air..most likely is the filter housing.
I just went through this my self.. since I was running a AD with the stock filter housing..I removed this last..all has been fine since. it was worse if I parked nose up..
-dkenny
Old Nov 16, 2010 | 07:12 PM
rebal's Avatar
start with fuel lines /filter/ filter drain /fuel heater/ there is a lot of places. this should get you going if not come back will list more places to look
Old Jan 6, 2011 | 05:49 PM
Fernando's Avatar
I'm having the same problem but I'm thinking its the heater grid. I'm going to run it soon and see if the headlights dim like they used to when the heater cycles. If so there is a load on the electrical and the grid is prolly OK, I'm thinking.
Old Jan 13, 2011 | 08:27 PM
Fernando's Avatar
I replaced my grid relays and the truck starts and runs nice again.
flyingd
17
Jul 11, 2017 11:13 AM
97catintenn
Jan 7, 2010 11:33 PM
fivefive1978
Sep 17, 2007 09:01 PM
JD730
Aug 2, 2005 11:33 AM
whiteknight
Jun 29, 2003 03:44 PM
