whats this noise?
whats this noise?
Hey guys,
I have recently bought (Jan 06) this truck (93/4wd/auto/99k) and i now am noticing a "clunking" sound whenever i put it in reverse, its definitely coming from the rear of the truck, what do yall think it is? its not as noticeable putting in drive, just rev....
whats this noise?
thanky,
I hope u joint, maybe it'll be allright until i get "roun to it", if it cant destroy anything else (not a daily driver) i can live with it a while longer..
Originally Posted by Necred
thanky,
Edwin
As was said, check the u-joints first. If they are tight, it's the cross pin in the diff if it's an open rear. If it's a power-lock the clutches are gone, and it'll be a little more difficult and expensive. You can see pics of that ugliness in my photo gallery. Somebody posted pics of a cross pin worn more than halfway through, but I forget who. Reider Racing has the parts for either diff, you should have 32 spline axles. http://www.reiderracing.com/spidergear_kits.htm
Chock the tires, put the t-case in neutral, get under the truck and twist the drive shaft hard each way. Pay close attention to the yoke going into the diff. It could be a combination of wear in the diff and a bad u-joint.
A buddy of mine lost the front rear-shaft U-joint on his M715 this weekend. It trashed the end of the shaft, kinked it, and may have messed up the hydraulic plumbing for the hoist. What it didn't do is the Worst Case Scenario: catch on a pavement defect (crack, pothole, etc) and flip the truck end-over-end. This is why I pay particular attention to the maintenance and condition of this one U-joint, FWIW.
- Chris
- Chris
flashgordon
Mar 26, 2006 01:27 AM
The Domie
Jan 6, 2005 02:23 AM
spassey
Jan 25, 2003 12:08 PM
