Whats that noise?
Old Dec 5, 2003 | 11:44 PM
wagontrain131's Avatar
Whats that noise?
At about 65-70 mhp on the interstate I've got a bad droaning and roaring kind of noise. It has just started in the last couple of months. I know my transmission is going bad, could that be it? Change of subject. Can anyone in the Birmingham Alabama area help me with the kdp, I'm not too sure i want to tackle it alone. Thanks for all the help
Old Dec 6, 2003 | 05:59 AM
bulthisl's Avatar
Re:Whats that noise?
Have you changed your exhaust or is it stock.
Straight pipes and some aftermarket pipes have a drone at about 2200 rpms.
If you have 3:55 gears that is the rpm range you would be at with the speed you described.
: Eddie : 8)
Old Dec 6, 2003 | 10:50 PM
Nope no exhaust mods, you think i might have a hole or a leak?
Old Dec 7, 2003 | 12:05 AM
Rare1's Avatar
Your tires have an aggressive tred. They might have worn unevenly now to the point of making noise at freeway speed.
Old Dec 8, 2003 | 08:29 AM
Paul Winey's Avatar
Wagontrain131:
I've got a similar problem still trying to find. If it's the tires then you should have the same droan when coasting in neutral (you may have to find a hill to keep up speed). If it disappears when coasting then could be tranny or may even be cooling fan clutch going south. Just some thoughts.
Paul
Old Dec 8, 2003 | 11:41 AM
gunracer1's Avatar
the baffles sometimes fall apart in the stock muffler. might want to check that also.
Old Dec 8, 2003 | 05:03 PM
Thanks guys for all the reponses. I'll check into your suggestions.
Old Dec 21, 2003 | 03:31 PM
Lil Red's Avatar
If none of these suggestions work, I had a similar noise in my truck. Thought my rear end was goin bad turned out to be my carrier bearing. Started makin a slight roaring noise then after about year and a half it got worse. Replaced the worn out carrier bearing and no more noise at all.
Necred
Apr 4, 2006 07:26 PM
flashgordon
Mar 26, 2006 01:27 AM
The Domie
Jan 6, 2005 02:23 AM
n2diesels
Sep 19, 2003 08:10 AM
spassey
Jan 25, 2003 12:08 PM
