What are the effects of bumping the timing
Old Feb 19, 2008 | 08:06 PM
91.5 beater's Avatar
Arrow What are the effects of bumping the timing
Can this hurt the engine in any way? Is there any worries about the valves or the tops of the pistons gettin too hot and not knowing cause the egt's show cooler? How far do you all reccommend goin with it? How far off are the EGT's gonna be? I am just kind of parinoid about doin this but i have heard good things about it. Your suggestions are greatly appriciated.
Old Feb 19, 2008 | 08:48 PM
sixgun4x4's Avatar
what is the 3200 rpm spring do. i have a 92 beater my self just a crankd pump
Old Feb 19, 2008 | 10:52 PM
It is the gorvernor spring and i guess it just governs the motor less. Put one in and you will be extremely satisfied with it, it feels like it doubles your power, it is amazing what $16 bucks can do for power on these trucks.
Old Feb 20, 2008 | 04:24 PM
An 1/8" bump will do fine for you, it won't hurt anything.
Old Feb 21, 2008 | 10:38 PM
93beater's Avatar
ok dave i have posted sevearl times about this timing and can seem to get a good answer, does it add power i have mine bumped like 1// or 1/4 about an inch away from the head persay.. i just wanna kno if its adding power and making my valves hot. truck is runnin best it ever has
Old Feb 22, 2008 | 06:38 AM
Bruce M's Avatar
Will the 1/8 bump increase mileage?
Old Feb 22, 2008 | 09:58 AM
93beater's Avatar
bump.........
Old Feb 22, 2008 | 10:06 AM
Jschlachta's Avatar
What advancing the timing will do is move the power cure higher in the rpm range. Also give slightly more time for the fuel to burn before the exhaust valve opens, which it what gives you better fuel mileage. Also note that this increases the cylinder pressure. My thoughts in a nutshell.
Old Feb 22, 2008 | 10:10 AM
rebal's Avatar
1/8 " will help mpgs ,it will lower EGTs but it increace cylinder pressure (to much timing will or can blow head gaskets ) timing will help upper rpm HP lower bottom end hp a little but for the most part its a plus .if you run propane dont advance propane will automaticly do that
Old Feb 22, 2008 | 01:29 PM
93beater's Avatar
ok thats what i was lookin 4 thanks fellas
Old Feb 22, 2008 | 07:25 PM
ILLINOISRAM's Avatar
I had a 92 that i put a new pump on. I had the gspring kit and cranked the fuel screw all the way in and jammed the pump against the block. This along with 300 marine injectors, new intercooler, and a 12cm housing on stock h1c turbo did right at 300/700 on Dunbars dynojet at indy. Was probably the funnest most reliable truck i have had. It towed great too. Wish i would have kept it for a daily driver. Even with the timing bumped all the way, never had a head gasket problem. Mileage was good too about 15 to 16.
jjj_85
May 22, 2008 02:59 PM
Elohim1
Apr 6, 2008 07:53 AM
speedybeedy
Sep 4, 2007 12:54 AM
cumminsdriver635
14
Apr 18, 2007 01:11 PM
mr T
Apr 19, 2005 08:22 PM
