Bumping timing questions
Old Apr 5, 2008 | 08:37 PM
Elohim1's Avatar
I read wannadiesels sticky.
1) What is "AFC housing" ?
2) Loosen three bolts and rotate towards head , Thats it?
3) Doing this lowers egt's, reduces smoke, gives better mileage and HP ?
4) Are there negatives to doing this?
Thanks
Chris
Old Apr 5, 2008 | 08:43 PM
BC847's Avatar
1st Generation Admin
Read this ~ http://dodgeram.org/tech/dsl/FAQ/timing.htm
Old Apr 5, 2008 | 09:08 PM
Alwaysworking's Avatar
alwaysonDTR
there are 4 bolts. 3 on pump 1 on brace
push towards the head
Old Apr 5, 2008 | 09:12 PM
Elohim1's Avatar
Originally Posted by BC847
Good info. !!
What is rated RPM (as described in the link) ?
Old Apr 6, 2008 | 06:37 AM
Rafter B's Avatar
How far do you push the pump towards the head? Thanx!
Old Apr 6, 2008 | 07:53 AM
Originally Posted by Elohim1
Good info. !!
Rated RPM is the RPM where the engine is designed to develop peak HP.
For a truck with stock injectors, an 1/8" (measured at the match marks on the pump and timing case) works well. With big injectors, shoving it to the head works pretty well.
jjj_85
May 22, 2008 02:59 PM
91.5 beater
Feb 22, 2008 07:25 PM
speedybeedy
Sep 4, 2007 12:54 AM
cumminsdriver635
14
Apr 18, 2007 01:11 PM
mr T
Apr 19, 2005 08:22 PM
