Questions about installing a boost pressure gauge
Old Feb 20, 2008 | 08:55 PM
Billut's Avatar
Hi all:
I got the complete boost pressure guage kit, but no diagram or instructions as to installation. There is an older thread with about 4 posts on the subject, but it does not answer my fundamental question: where do you plumb the "sensor" or whatever it's called. Being somewhat challenged by explanations, and pictures being worth a million words in my book, if any of y'all has a picture to show where to plumb, I'd be really grateful.
Thanks for your understanding, I might need some compassion, too, I guess...
Old Feb 20, 2008 | 09:25 PM
MBolivar's Avatar
Billut,
There is a plug in the area underneath where the intake horn goes into the manifold/head. Take that plug out and replace it the the brass fitting and ferule that came with your gauge. Try doing a search as I believe there were some pics on this subject.
Aloha,
Matt
Old Feb 20, 2008 | 09:36 PM
MBolivar's Avatar
Billut,
I found a pic for you.
Aloha,
Matt
Attached Thumbnails Questions about installing a boost pressure gauge-boost-sensor-fitting-install-closeup.jpg
Old Feb 20, 2008 | 10:26 PM
stackx2's Avatar
man you beat me to it
Attached Thumbnails Questions about installing a boost pressure gauge-imported-photos-00056-%5B800x600%5D.jpg
Old Feb 20, 2008 | 10:43 PM
MBolivar's Avatar
John,
Your's is a better pic.
Aloha,
Matt
Old Feb 21, 2008 | 08:59 AM
Billut's Avatar
Man, this site is awesome! There's always someone out there to share their knowledge, and that's invaluable to those - like me - who miss it badly.
Matt and John, thanks so much for the pics and the explanation!
Old Feb 21, 2008 | 09:41 AM
1-2-3's Avatar
Just a plain ole guy
Ive got a 24v and I'v ebeen wanting a boost gauge. Is the same plug there on mine? That sure would be sweet if it were.
Old Feb 21, 2008 | 10:34 AM
stackx2's Avatar
i dont think so, but im not up to snuff on 24v. you could tap your air horn and plumb it in there. you probably should check in the 24v forums, they would have a better answer for you
Old Feb 21, 2008 | 06:04 PM
sparky 12valver's Avatar
just noticed this, will it work for my boost port?
Old Feb 21, 2008 | 06:46 PM
It looks like somebody already installed a gauge there. Where's the line go?
Old Feb 21, 2008 | 06:49 PM
in the cab by the fuse block, do you think that location will work on the intake housing
Old Feb 21, 2008 | 06:55 PM
Yes, that will be fine.
Old Feb 22, 2008 | 02:06 PM
1-2-3's Avatar
SO all you need is basically a pressure gauge between the turbo and the intake.
Old Feb 22, 2008 | 03:14 PM
andyr354's Avatar
Kind of interesting they went to all the work of tapping the intake horn when there are two empty plugs in the intake already. Must have been a 24v guy install it.
The 24v does not have an easy to use place in the head. There is a large tapped hole towards the rear by the MAP sensor but IIRC it is a harder to find metric size. Most with the 24v trucks drill and tap the intake horn like in the pic above.
Andy
Old Feb 22, 2008 | 07:29 PM
Loosewire's Avatar
I HAVE MY BOOST GAUGE INSTALLED IN THE AIR HORN GOING INTO THE INTAKE. WORKS GREAT FOR ME.
[IMG][/IMG
YES, THAT IS A BEER KEG. I MADE ME A COOLANT PUKE TANK OUT OF IT.
jcamron
Aug 12, 2009 12:40 PM
Ernst223
15
Mar 7, 2008 03:49 PM
reedad
Jan 27, 2008 06:50 PM
ryan88
Jul 7, 2007 02:07 PM
Lightman
50
Oct 24, 2004 04:02 PM
