Old Apr 14, 2019 | 08:36 PM
  #7186
edwinsmith's Avatar
That looks just like my 89 when I first got it! Same under the hood exactly. H1c turbo has to go. Your paint is a lot better than mine was though.
Edwin
Old Apr 15, 2019 | 01:41 AM
  #7187
Man $1500...you stole that thing!! Congrats looks like a sweet truck. That your shop addition, or were you working on that site?
Old Apr 15, 2019 | 02:56 AM
  #7188
KRB's Avatar
KRB
Yea, a very good deal. What part of the country? Looks like it is well preserved.
Old Apr 15, 2019 | 08:41 AM
  #7189
nothingbutdarts's Avatar
Yes, my best friend does concrete work and did the foundation & his helper does construction, between the 3 and sometimes 4 of us we put up the 24 X 30 garage. I'm now working on electrical than on to getting it insulated & heated as monies let me. It's in Bailey, Co.
Old Apr 15, 2019 | 02:57 PM
  #7190
I just finished and had my inspection on my electrical on my shop....just have to finish the rest now.
Old Apr 15, 2019 | 05:03 PM
  #7191
I plan on doing the very basics needed for a final inspection then finish wiring it after that.
Old Apr 17, 2019 | 08:46 AM
  #7192
So, yesterday, I wound up on the side of the road...... AGAIN !
Truck died exactly the same way it has over, and over and over and over and over again. I ran out of fuel in the filter.
Every time this happens its exactly the same thing.
I'm driving along 50mph to 70MPH, minding my own beeswax, and the pedal starts to fade.
The fuel gauge reads 1/3 full (about 9 gallons or so)
Fuel pressure said 7psi or so until it died
Make my way to the shoulder with zero power steering, and pull the fuel filter. EMPTY.
Get out my trusty diesel "save me on the side of the road kit", and I refill the filter, bleed the injectors, and it fires right up.
Drive to the local fuel station, and filler up. I guess I'll break down in a month or two again, as it seems to happen ever few months or so.
This time I wasn't raped hundreds of dollars being towed, as I have my 17mm wrench, my fuel filter wrench, rubber gloves, and quart of diesel sitting behind the seat in the side well. Less than 10 minutes, I was back up on the highway as if nothing had ever happened.
FRUSTRATING.
So, I'm going to replace that fuel reservoir and suction line from tank to lift pump with new hose and pickup in the tank. Thanks Oliver!
UGH.... Stupid air leak. Gets old, when you're getting old. Turned 52 last week, and I'm tired of this crap. I just want the thrill of driving my ride and having guys in Ferds pull up and say..... "Hey dude..... Awesome Rig ! ", like the fella in this black pickup did yesterday....
lol I guess he couldn't tell that my truck is a Dodge and not a Ferd.....
Lol
Still 9 plus gallons left
Dude in a Ferd
Old Apr 17, 2019 | 10:13 AM
  #7193
mhuppertz's Avatar
A friends Duramax would do this same thing, turned out to be a factory fuel supply hose sucking flat. Different setup I know, but was a hard one to find.
Old Apr 17, 2019 | 10:23 AM
  #7194
Fordzilla's Avatar
My one and only Ford did the exact same thing for the exact same reason......Ben
Old Apr 17, 2019 | 06:23 PM
  #7195
edwinsmith's Avatar
Whenever my truck gets down below 1/2 tank it gets hard to start. It still starts but I have to crank it a bit before it sputters to life. This is in contrast to just touching the key and having it running. Oliver suggested it might be the suction tube in the tank having a hole in it. I've tried pressurizing the tank and looking for leaks but nothing found.
Edwin
Old Apr 17, 2019 | 08:59 PM
  #7196
WynneWyatt's Avatar
Wipers only 1 speed
I only have 1 speed on mind, fast and nothing else. Changed motor , relay and blinkers control from one that was working correct. Any ideas.
Originally Posted by d9inger
Today I replaced my wiper motor, the intermittent controller and the co-pilot side power mirror.
Might not seem like much but I have a huge feeling of satisfaction..
Next is the KDP mod, 4" exhaust, cold air intake, etc.
Dave
Old Apr 18, 2019 | 11:05 AM
  #7197
J33p's Avatar
I got home a bit early last night, so I was able to spend a bit of time putting my front hubs back together with a new set of MileMarker Premium Hubs. Flushed the power steering lines, and got the steering box plumbed and filled. Ahhh back to making progress.
Old Apr 19, 2019 | 05:49 PM
  #7198
Since I love my noisy old truck, I had to live vicariously and drove it up north NJ to see a prospective customer.
Full tank of fuel, of course
No issues other than a few bugs in my teeth from enjoying the ride so much.
Came home to see my friend Oliver sent me some goodies. My next victim , and my next victim. Starter rebuild for Ollie, and replacing my fuel reservoir so I can disassemble the original one to see if the pigs tail plastic diptube is cracked or not.
Thanks Ollie! You're the best no matter what your girlfriend says.
Old Apr 20, 2019 | 07:31 AM
  #7199
NJT - Glad you are enjoying the old 1st gen! Good to see the parts showed up safely and still in good shape.
We are getting about an inch of rain up here over a 24 HR period. That should be enough to wash the last of the salt off the road.
I look forward to pulling Poncho out and getting back on the road next week!
I have a little more to do to finish up re assembling the front end of the black crew cab. It can then come out of the shop after 4 years of being down. It got a lower mile replacement 12V, with a bunch of new gaskets, a HVLP LP, a resealed VE pump with the 3200 spring and a bunch of other little goodies. An Autometer tach with the magnetic pick up that runs off the alternator was also installed as I had it floating around on my shop shelf.
Looking forward to driving the line up of old 1st gen conversion crew cabs, the '89 Ramcharger and Poncho.
I have to choose one for my daughter and I to take to Carlisle here pretty soon.
Old Apr 20, 2019 | 08:32 AM
  #7200
Fordzilla's Avatar
Why choose?...Take 'em all...I'm pretty sure you could find enough volunteer drivers here for convoy duty......Ben
