What is the best way to make an electrical connection?
Old Sep 16, 2008 | 05:07 PM
TJE's Avatar
TJE
solder, wire nut, etc.
Thanks, Tony
Old Sep 16, 2008 | 05:08 PM
Solder is by far the best.
Old Sep 16, 2008 | 05:13 PM
D68's Avatar
D68
what kind of wires you connecting ?
Old Sep 16, 2008 | 05:23 PM
TJE's Avatar
TJE
Actually what I'm connecting is my A/C temp cycling switch....a mechanic cut the male, female plugs off so I'm putting them back on, and installing a new temp switch. The wires are 20 gauge so I'm thinking that solder may not work in the situation.
Thanks for the help, Tony
Old Sep 16, 2008 | 05:25 PM
D68's Avatar
D68
so thats aperminent connection definentley soder an shrenk rap
Old Sep 16, 2008 | 05:27 PM
archer39's Avatar
a proper solder is the best then i would say a high quality butt connector.
Old Sep 16, 2008 | 05:33 PM
D68's Avatar
D68
if your not going to solder then posi lock it
Old Sep 16, 2008 | 05:43 PM
NotEnufGarage's Avatar
Solder and Shrink tubing
Old Sep 16, 2008 | 05:57 PM
BearKiller's Avatar
The best electrical connection has many answers, depending on just what is being connected to what.
For wire to wire splices, strip an appropriate length of both wires, CLEAN the strands until shiny, lay alongside each other and twist tightly together, heat the splice until solder runs freely throughout the joint, let cool, then insulate with two or three layers of shrink-tube.
If splicing wire 14AWG or larger, instead of the twist-together splice, use un-insulated BUTT-connectors, crimped heavily, then solder-filled, then the three layers of shrink-tube.
Cut the first layer of shrink-tube the same length as the naked splice, the next layer about 1/2" longer, and the third 1/2" longer than the second.
Old Sep 16, 2008 | 06:54 PM
Richie O's Avatar
366 Spring Chicken
I have good luck with heat shrink butt connectors from napa. I use them on my lobster boat for all connections and they hold up good and thats with salt spray everywhere.
Old Sep 16, 2008 | 07:33 PM
C Pierce's Avatar
What BearKiller said! Richie O I tried those heat shrink butt connectors but when I crimp them It tears through the shrink what kind of crimper tool do you use?
Old Sep 16, 2008 | 08:49 PM
Richie O's Avatar
366 Spring Chicken
Just an old pair of stripper / crimpers. Mine must not be as sharp as yours.
Old Sep 17, 2008 | 01:00 AM
C/PRD/'s Avatar
I would only recommend soldering. A small rosin solder makes "tining" quite easy with a decent iron. As for shrink tubing, use a filled tubing, not the junk GB brand that can be slipped off after shrunk. Remember that your enemy is electrolosis, moisture is in the air so make it "air tight". And I ussually solder 26ga twice a week at work.
thenrie
Apr 15, 2010 10:34 AM
98DRQC12V
Jan 17, 2010 09:58 PM
RottnRam
May 25, 2008 05:13 PM
granahan378
Nov 17, 2007 11:37 AM
