WH1C Intake duct
Old Mar 15, 2005 | 04:12 PM
edwinsmith's Avatar
WH1C Intake duct
I'm still gathering parts for my WH1C conversion and I need to get some different ducting from the air cleaner to the compressor intake. The stock H1C is much smaller.
Is there a generic ducting available in different sizes? I might go to a BHAF later on also.
Thanks
Edwin
Old Mar 15, 2005 | 04:27 PM
G1625S's Avatar
www.airflo.com
two rubber 4'' 45's and a couple feet of 4'' intake pipe and some clamps. I think that's where wannadiesel got his intake stuff---plus, they've got STACKS
greg
Old Mar 15, 2005 | 04:28 PM
G1625S's Avatar
oh, plus they've got 3''-4'' adapters
g
Old Mar 15, 2005 | 04:29 PM
G1625S's Avatar
oh, but you won't need that 'cause of the new turbo I'll just zip it, now
Old Mar 15, 2005 | 04:44 PM
edwinsmith's Avatar
What about using 4 inch plastic sewer pipe?
Old Mar 15, 2005 | 05:48 PM
loch's Avatar
im not sure how much heat it takes to soften pvc, if it got very soft it would suck it shut id think.
Old Mar 15, 2005 | 05:54 PM
edwinsmith's Avatar
I think the black stuff is ABS. I'll see if I can find an MSDS on it.
Old Mar 15, 2005 | 06:29 PM
ChrisLib's Avatar
I had thought of using PVC/ABS tubing but the thought of it shattering when extremely cold due to the vibration these engines produce steered me away, besides the whole deal from airflow, 45`s tubing and clamps was under $50 IIRC.
Old Mar 15, 2005 | 06:45 PM
Den's Avatar
Den
I think the PVC gives off nasty fumes when hot.
Wannadiesel has a nice setup I wouldn't mind copying. Here's the link and in the description it lists what he used and where he purchased them
https://www.dieseltruckresource.com/...cat/500/page/1
Maybe he can add some details here
Den
Old Mar 15, 2005 | 06:50 PM
Nothin' wrong with PVC for the intake duct, I've seen it under the hoods of pulling trucks.
You can use a chunk of exhaust tubing, or the aluminum tubing like I used, it doesn't really matter. Whatever is available and fits your budget, use it.
Old Mar 15, 2005 | 09:20 PM
edwinsmith's Avatar
I'm thinking I may try adapting the stock hose that I have to begin with. The place wannadiesel got his fittings from has aluminum tubes though so I would probably go with that. If I could adapt the flexible hose I have it might make changing air filters easier by some but maybe not. The flex isn't much flexible anymore.
I still need to couple the output of the compressor to my crossover. I guess I'll have to wait till bolt on time before I can see how to do that. I'm thinking I mucht get a hose reducer and just clamp it on but the flange on the output of the compressor might not work well with that. I hate to do any welding cutting etc... on the turbo or the crossover but since the crossover pipe shrinks down to less than 2" I thinking I might take it to a shop and have it enlarged to 3" to flow better. The 2" seems awful restrictive.
Thoughts?
I have found a good used 12 cm WG housing that isn't cracked on eBay so that's covered.
Edwin
Old Mar 16, 2005 | 08:23 AM
Alec's Avatar
I would think about trying to get the 90 elbow that clamps on to the compressor outlet on the aftercooled trucks, and then adapts to hose. You could clock the turbo so that kicked up and over toward the valvecovers, and then mod the crossover pipe to accept the new larger boot as you described. Later if you want to put an aftercooler in the truck, you would be that much further along.
Just a thought.
Old Mar 16, 2005 | 12:22 PM
edwinsmith's Avatar
I have not seen the aftercooler setup so I didn't know what parts were involved. The 90 degree elbow would make for a long piece of hose, 8 inches or so, to connect to the crossover pipe. It would be nice if I could get a simple straight piece that clamped to the compressor and would allow for a hose. Then I could probably mate it with a rubber reducer and clamps. That way I could put everything back stock if need be.
If anyone has any of these parts please chime in.
Thanks
Edwin
u.s mma
Aug 12, 2009 05:41 PM
CarBizIndio
Jun 23, 2007 09:37 PM
wyomingkid
Jan 14, 2007 12:41 PM
JWHenson
Jul 2, 2006 04:37 PM
