Wait to start light
Old Jun 14, 2009 | 10:16 PM
Canso's Avatar
Wait to start light
When I went to start my truck today the wait to start light would not go out. After it fired the WTS light started blinking. Anyone ever seen this before?
Old Jun 14, 2009 | 11:25 PM
gear jammer 91"'s Avatar
I have heard of this before but I can't remember exactly what the problem was. I think it means that your grid heater isn't working properly, or that the relay that controls it is bad. Somebody that actually knows the answer will chime in here soon.
Old Jun 15, 2009 | 06:25 AM
Jim Lane's Avatar
Have you recently got your engine wet? Every time I wash my engine my light comes on until I dry the connection with compressed air.
Did you try and open the drain, there might be just enough water in your filter to make the light come on and the vibration of the engine is making it blink.
Try disconnecting the WIF sensor at the filter and see if the light goes out, this will rule out any water in the sump or WIF sensor problems then if it is still on.
I do not believe the WIF light has any dual function other that when it goes through it's POST sequence especially with your early 1st. Gen.
I would think.
Jim
Old Jun 15, 2009 | 07:40 AM
Canso's Avatar
It is my wait to start light that blinks, not my water in fuel light. It blinks at a set pace, a little slower than the turn indicator, I will make sure all my plugs are dry and clean. Thanks so far.
Old Jun 15, 2009 | 12:26 PM
An open circuit in the air temp sensor circuit will make the WTS light blink on a non-intercooled truck. Did you unplug it and forget to plug it back in?
Old Jun 15, 2009 | 02:40 PM
Jim Lane's Avatar
Oh geez I read WTS about 5 times and still saw WIF, what was I thinking.
Where does the open circuit flash signal come from, the message center or is there a controller somewhere behind the dash?
On my GM 6.2 the WTS light would flash about 1/sec when the glow plug controller would burn out.
Old Jun 15, 2009 | 04:41 PM
That's a function of the brain box on the firewall.
You can use this feature to test the system. If you unplug the sensor and then turn on the key, the relays should both kick on.
Old Jun 17, 2009 | 07:19 AM
Canso's Avatar
Where abouts is this open air sensor. I pulled my rad out awhile ago, I dont think I unplugged any wires.
Old Jun 17, 2009 | 05:56 PM
Sticks out the side of the intake horn just below the dipstick tube.
mitm
May 20, 2014 12:32 AM
jriggs_18
Jan 11, 2007 04:43 PM
loosendend
Sep 4, 2006 12:01 PM
bfarrell
Nov 30, 2005 03:23 PM
59FORD
Aug 10, 2005 08:09 AM
