Questions about buying HX35
I'm looking to buy an HX-35 Turbo for my truck to upgrade to a 4" downpipe, just had a few questions:
Good price to pay *NEW* from ebay or similar site?
Used Junk yard good condition turbo with no play, pricing?
Does it bolt right up?
What size housing should I look at getting?
All I should have to do is block off wastegate and I'm good to go, is this correct?
My truck is used mostly for play and occasionally pulling my wheeler, EGT's aren't a huge issue as I drive like an old man anyway.Thanks guys!
No it doesn't. it has 3" like the H1c.
the hx40 has a 4" outlet, the true hx40, not a hybrid 35/40
An hx40 is a great upgrade, look for a 60/65/16 HX40.
An HX35 is not really an upgrade over your 93 H1c because the compressor wheel is the same size, the hx35 will have a small 12cm housing that will get hot on an auto truck.
It'll spool fast and sound cool, thats about it.
Sound and spool doesn't seem worth it .. although I do like sound
What would you suggest then? Is this what I'm looking for? http://cgi.ebay.com/ebaymotors/HX40-...Q5fAccessories
there,s more to a turbo than compressor wheel size, comp.housing, mwe slot , there are 2 different variations of the 35 used on 2nd gens. i have one of each i,ve put hx,s on several 1st gens, its not a huge upgrade but a good upgrade,especially in the $200 price range
crossy,s son, my response to your post was in no way a put down of your statement , you seem quit knowledgeable and i enjoy your posts. i have found the hx to be a decent upgrade for the money. certainly not a huge upgrade. i do a lot of testing / tinkerining with different turbo/ exaust housing/waste set-ups to see what works best at my elevation. i would love to see how a big turbo spools and feels down low. maybe my results here are a little different than you low elevation guys. i usually tow from 5000 to 8000 ft. most guys around here that go real big on compressor wheel spool real slow.
What would you suggest then? Is this what I'm looking for? http://cgi.ebay.com/ebaymotors/HX40-...Q5fAccessoriesawesome upgrade would be this PDR HX40- http://www.pdrdiesel.com/products/PD...s-1086-26.html I believe "gearjammer" on here has one, they take an already good 400Hp turbo and do they're modifications to it to make it better. 4" outlet
or if you wanna have a turbo that you'll never have to upgrade- http://www.pdrdiesel.com/products/Cu...bo-915-26.html
Just throwing some things around, you could also do the 05-07 3rd gen HE351 turbo upgrade if you can find one cheap enough, 4" outlet and 15+ years more of turbo technology and they spool super fast. crewcabxlt has one
I wasn't offended Crewcabxlt
I like trying to get people to spend money on here
Brandon
since a few guys are doing some R&D on he351's, from what i've been reading, it does spool quickly due to it's 9cm housing size and would be good for around town, no-load driving on a manual truck. but also because of the 9cm housing, it doesn't perform well under towing, loaded conditions or top-end power because it's reached it's maximum pressure and by then is just pushing hot air. am i correct on the info that i've gathered? i'm just doing my homework for when it comes time for an upgrade. i haven't done any towing since i've had the truck but i'd like to have a turbo that would spool fast when driving around town and that would be fine when under a load or when i'm towing and not have to worry about over-speeding it and it exploding. in other words, i'm looking for the best of both worlds lol
I love my hx-35. If you leave your truck relatively stock you will love the hx-35. I don't know much about egts with auto trannys, but my egts went down A LOT when i put an early hx-35 on my 5-speed. I went from 19 lbs at about 1100 degrees to 28 lbs under 1000 degrees. (still going to hook up the waste gate) The great thing about hx-35s, is that they came stock on 95-2002 2nd gens (except late autos), and you can pick one up for around $250. I got mine for $120 Check classified ads, and there are a lot on cummins forum.
there are others on here running the he-351,maybe they have more info. i have found the opposite from your thinking to be true. i cant believe how this turbo cools top end boost. 35 to 40 psi it really shines. ive only towed 2 times in the mountains and it really uot performed my hx. even at 40 + psi i struggle to hit 1200*. high rpm seems to push it more to max. ive now set my wastegate at 38-40 psi. i,ll post info as i get more results. i dont want to over rate the turbo but so far im impressed. my experience towing is the smaller housing run cooler when operating 1500-2500 rpm. it takes air to cool. more than flow out the back.
