Truck won't shut off.
Old Feb 28, 2007 | 05:22 PM
wedgepower's Avatar
91 Dodge CTD
It won't shut off with the key.I tried unplugging two solenoids under the injection pump,no luck.I had to choke the supply line to the pump.
What is the fix?thanks.
Old Feb 28, 2007 | 05:26 PM
Sounds like the tip of the plunger in the shutoff solenoid got ripped off. There's a write-up on how to fix it in the sticky.
Your local VW dealer has the solenoid for about half of what Cummins wants.
maxx250's Avatar
I just went through the same thing with my 91 ,turned out to be the shut off solenoid on the pump.I was able to order one through o'reilly auto parts for 75 bucks.That seems to have taken care of it.
Old Feb 28, 2007 | 05:30 PM
wedgepower's Avatar
Got a VW part number?
Which solenoid is it?
Old Feb 28, 2007 | 05:37 PM
Micaiahfied's Avatar
what do you mean when you say choke the supply line to the pump? if this isn't what you are talking about, there is a lever on the side of the pump that will cut off the fuel supply. some guys have given up on the solenoid and attached a choke cable to shut it down.
Old Feb 28, 2007 | 05:40 PM
wedgepower's Avatar
lol.I thought that was a primer lever.I clamped off the rubber supply line.
I just need to get through a few days.This is my work truck and I'm too busy to deal with this right now.That and it's almost 5,so parts houses are closing.
Old Feb 28, 2007 | 05:44 PM
use the lever on the side of the pump to shut it down, and if you have something to rig up, run the line into the cab so you can shut down semi-normal (without popping the hood every time you stop) until you have time to fix it correctly.
ALSO, as long as the solenoid is working and it's just the tip that's busted i believe there is something in the sticky that will show you how to make yours work again... others will correct me if i am wrong.
Old Feb 28, 2007 | 05:45 PM
BearKiller's Avatar
Primer lever is on the lift pump.
Shut-down lever is on the injector pump.
I don't know what would happen if someone got the two mixed up and tried to shut-down with the primer; but, I can't imagine the experience being good.
Old Feb 28, 2007 | 05:47 PM
maxx250's Avatar
Thats good stuff Bear
Old Feb 28, 2007 | 05:54 PM
wedgepower's Avatar
Ahso grasshopper.
FYI,shutting down the primer doesn't seem to hurt anything.DAMHIK
I read the sticky.Can I remove the solenoid and mess with it in my rare spare time or will it spew gas?
Also,which one is the solenoid,the one on the back of the pump with 2 wires or the one on the side with 1 wire?
Thanks guys!!!!
Old Feb 28, 2007 | 06:07 PM
You can take out the plunger and spring, then put the body back on and drive the truck, you just have to use the manual shutoff.
Solenoid is the 2 wire one.
If you go to VW, just tell 'em it's for an '85 Golf diesel.
Old Feb 28, 2007 | 06:09 PM
SMOKE' EM's Avatar
you can grind down the plunger to metal and then put it back in also and it will shut off
Old Feb 28, 2007 | 06:17 PM
wedgepower's Avatar
Sweet.The it's special order from the dealer for $58.Compared to $70 from the diesel shop.I'll get it and then fix the old one and keep it as a spare.In the mean time I'm rollin with speaker wire.
Thanks!!!!
Old Feb 28, 2007 | 06:53 PM
GIT-R-DONE's Avatar
http://rep.racepages.com/parts/racep...owdc=false#top
I think this is the one you need.
Old Feb 28, 2007 | 11:01 PM
ppiggppenn's Avatar
makes sense, the VWs used Bosch too in any of their Diesels I ever saw.
dkimmel
Jan 3, 2011 10:54 PM
randyswelding
Feb 9, 2009 10:40 PM
HAMMER_DOWN
Nov 14, 2007 04:40 PM
wedgepower
Feb 28, 2007 05:57 PM
ddog87
Aug 2, 2006 03:40 PM
