Triple Disk Torque Converter
If I understand correctly, a A518 trans has a non lock-up TC and an overdrive
unit in the trans. Correct?
Is an aftermarket triple disk converter a type of lock-up converter upgrade?
Could someone please enlighten me on how it works?
so if I get one I'll have OD plus a lock-up TC?
What would I need to do to make it funtional?
another switch in the cab?
or do you just not run it in lockup in our application?
You just get a non-lockup torque convertor for the A518. There are plenty of companies that make them.
The transmission that has lockup is called a 47RH, aka A618. You can't just add a lockup torque convertor the the 518 and make it a lockup transmission, there's more to it than that, but I don't know what else you need. There are people who know more than me and they will probably post later.
you'll need a different input , different valve body, a different pump a different engine adapter
Easier to just get a 94-95 47rh trans and swap it in or just buy a tight converter for your non lockup A518 which is what i'd do.
Basicly it's a pain to convert your 518 to lockup, there's alot to it.
From what I have heard the trans company P.A.T.C. has made a electrical hook.up that makes it a lock up,only in 4th gear @ 55 mph maybe in 3rd gear, yes you need to buy alock up converter,part from P.A.T.C. is $65.or $85.00. I don't work for company just read there web page check out there Mega Viper III rebuild it yourself,have a shop do it
To convert a 518 to lockup you would need to:
change the input shaft to a lockup one. Free to cheap if you know who to talk to.
change either the front pump or the shaft support to a lockup type. I bought a whole front pump for about $50 a few years ago from a trans shop.
add the required parts or acquire a 47RH valve body. I would get a whole valve body from a vender all setup.
secure the proper 3 pin connector for controlling lockup and OD. Junk yard or PATC.
A lockup converter of course. This is the expensive part if you buy a good one.
And the thicker engine adapter from 94 to 02. Hunt around, they are pretty easy to find.
Then to install it you need to follow the instructions in the following threads.
https://www.dieseltruckresource.com/...d.php?t=114702
https://www.dieseltruckresource.com/...d.php?t=236738
I'm pretty sure any lockup converter they make is the standard dimensions for a lockup one, about an inch longer than a non-lockup unit.
winkdemon
Aug 3, 2009 04:13 PM
Mike D
Dec 9, 2008 07:59 PM
DSjockey
34
Jul 20, 2007 07:03 PM
