Front U-joint question
Old May 25, 2011 | 10:32 PM
Lunds Ram's Avatar
I had to replace my rear u-joints today and went to grease the fronts and i noticed a lot of play in all 3 joints, im assuming the needle barrings are compleatly gone just like the back ones were. My question is would it be easier to replace the joints, or get a new shaft, or upgrade the joints to the same as the back ones?
Old May 25, 2011 | 10:38 PM
93flatbed's Avatar
If you were able to do the rear then the fronts should be do able for you. The double cardan gets a little tricky but not bad. A friend helps to have around for a spare hand. Upgrading would be nice. I suppose you could buy a whole new shaft if you wanted, but I would think it would be cheaper to do the work your self.
Old May 25, 2011 | 10:49 PM
Lunds Ram's Avatar
Well i'm planning on replaceing both shafts, it looks like the po never greased them and as i was pushing out the rear joints, a couple small pieces of the ring grove broke off, and the front has been loose since before i got it
72dart
Jun 19, 2012 10:42 PM
wcbcruzer
22
Apr 30, 2008 06:58 PM
FDC
Jul 16, 2007 12:51 PM
Treangen
May 7, 2007 03:10 PM
