Trany gurus, damage or bad machining?
Couldnt wait for the FSM to get here and tore down my A518 today. Have no idea as to this things past and everthing seemed in good condition until I saw the rear planetary:
these knicks are above 3 of the 4 smaller gears in the exact same spot, area around the 4th gear is smooth as margarine. Just dont know enough about trans' to guess what its from, whatchya think?
Also, I COULD NOT get the OD section off until I got the front planetary snap ring off and ended up pulling the output shaft out along with the OD section, only to pull the O/P shaft out of the OD section with a tug or 2. So what in Scoobys name did I do wrong?
Definetly decided on a new set, and I bought the trans in unknown condition, fluid was black as it could be. had a snapped off cooler line fitting to boot!
rockjeep73
Feb 20, 2006 11:49 AM
guzzirider
Nov 28, 2005 07:39 PM
localnet
Jan 9, 2005 11:58 PM
Diese
Nov 13, 2004 12:05 PM
