Top Dead Center Pin Thingie Question ??
Old Apr 12, 2008 | 10:26 PM
BearKiller's Avatar
Question Top Dead Center Pin Thingie Question ??
On the son's truck, on the fire-wall side of the timing-cover, just under the injector-pump and just above the vacuum-pump, close to the block, WAS a plastic pin-thingie and a blob of dried-out silicone-goop.
When I investigated, the goop, along with the plastic pin, fell into my hand, leaving an open hole into the entrails of the timing-cover.
This plastic piece is about 1-1/2" long, about 3/4" diameter, peg-shaped on the end that was exposed, conic-shaped on the bigger end, with about a 1/8" long by 3/16" diameter "tip".
There is a green O-ring in a slot around the body.
Other than the goop of silicone, I see absolutely nothing to hold this in.
Is this the peg that locates TDC ??
I sort of expected it to be spring-loaded.
What retains this in the engine ??
Is something missing on this one ??
Please help.
Thanks.
Old Apr 12, 2008 | 10:27 PM
There's supposed to be a circlip holding it.
Old Apr 12, 2008 | 10:41 PM
daking's Avatar
yes thats the top dead center pin, its not spring loaded, it shouldnt pop out, i dont know what holds it in on the other side probaly a c clip, but you must of had to pull really hard to get it out, or its broken and the other piece is in the gear or at the bottom of the cranck case, just stick it back in there and see what happens if its really lose put some silicon on it
Joel
Old Apr 12, 2008 | 11:01 PM
BearKiller's Avatar
Where is this "circlip" supposed to be at on the peg ??
How long is the little tip on a good one ??
A picture would be wonderful.
When I push this back in, it just slips back out.
Thanks.
Old Apr 13, 2008 | 12:14 AM
torquefan's Avatar
The circlip is kind of like a star washer that pushes into the plastic housing, after the pin. Its little teeth bite into the bore of the housing and prevent the pin from pulling right out of the housing. However, I've seen several that have the circlip missing, and there is enough friction on the pin's o-ring to prevent it from moving or falling out. Try installing the pin with a new o-ring.
The little tip isn't very long on the pin, seems to me they're only about 1/4 inch or so.
This is the only pic I could find, it shows the location of the pin, but you already knew that.
Old Apr 13, 2008 | 02:07 AM
BearKiller's Avatar
Is that sorta oval-shaped base that has the hole for the peg removable, as in can I get it out on the work-bench in order to re-engineer the thing, or maybe just put a piece of solid plastic between it and the timing-cover that will seal off the hole and not worry with the peg ??
In the picture just posted above, it appears that there might be two screws that, once removed, will allow the hole thing to come off.
If so, I will just block off the opening and put the peg in the tool-box.
Thanks.
Old Apr 13, 2008 | 02:10 AM
Chrisreyn's Avatar
yep, two phillips head screws, but they are a real PITA to get at....
every CTD I have had, that pin has been broken off, adn I tried removing one to replace it, could never quite reach the top screw without stripping the slots out of it..
Old Apr 13, 2008 | 02:17 AM
BearKiller's Avatar
Have you ever tried it with the injector-pump not on the engine ??
It's dark out there now, but I believe that, once I get an inch of grimy-gook gone so that I can actually see the screws, getting them out should be pretty straight-forward.
I just don't like to think about him driving around and that silly peg dropping out on the road, letting all the oil out.
Thanks.
Old Apr 13, 2008 | 02:19 AM
Chrisreyn's Avatar
Thanks.
No, not with the pump removed, that would make it easy!
Mine were all broken off flush with the pin-mount, so there wasnt an open hole, you just couldnt use it...
never have been able to set valves with any certainty.....
Old Apr 13, 2008 | 07:55 AM
Thanks.
If you take off the timing pin holder, it needs to be reset to TDC when reinstalled. At the factory the engine is set at TDC (or as close as the assembler feels like setting it ) and the holder and pin are installed.
If you want to remove the holder to repair the problem, use the pin to set TDC and don't disturb the engine until you reinstall the pin/holder assembly.
Old Apr 13, 2008 | 09:57 AM
BearKiller's Avatar
Are those two little screws in slots or something ??
How do the people whose locater has sheared off ever set their valves ??
How about if I draw an outline around the base, remove it for repair, and replace it back in the outline ??
Or, if I just blank it off, will I still be able to set the valves occassionally ??
Thanks.
Old Apr 13, 2008 | 06:59 PM
Are those two little screws in slots or something ?? There is appreciable slop.
How do the people whose locater has sheared off ever set their valves ?? You don't have to be perfectly on TDC to set the valves, just on the base circle of the cam will do.
How about if I draw an outline around the base, remove it for repair, and replace it back in the outline ?? I don't know how you're gonna see it to do that unless the pump is off the truck.
Thanks.
See my answer to the second question.
schamran
Dec 20, 2009 05:28 PM
BearKiller
Mar 25, 2008 06:26 AM
jimlj
Aug 17, 2007 11:46 PM
adidasman23
17
Jan 30, 2007 07:06 PM
MrSlug
Jan 11, 2007 06:11 PM
