Was think of a piston pump until
Old Dec 1, 2010 | 08:22 PM
93-12Smoke's Avatar
If you have a 15 PSI electric pump set up for your line size then starvations shouldnt ever be an issue. It feeds the fuel you need when it needs it.
Old Dec 1, 2010 | 09:28 PM
BearKiller's Avatar
Originally Posted by Bruce M
The 3933256 was replaced by the 3936320.
The 3936320 was replaced by the 4944714.
The 4944714 was replaced by the 4988751.
The spec on the 4988751 is 32-43 gph and 30psi.
I think you may have some numbers mixed up.
The 3936320 pumps on all the trucks that I have messed with hold a steady 14- to 17-PSI .
I believe the 3936316 2nd Gen. pump is the one that holds 30-PSI or thereabouts.
Old Dec 2, 2010 | 06:25 AM
I put a piston pump on the 93 and I noticed quite a difference in Topend power and ALOT of smoke cleared up!!
Old Dec 2, 2010 | 06:42 AM
Douglas2's Avatar
I got the same results from a Carter electric, 4601HP IIRC.
cheers,
Douglas
Old Dec 2, 2010 | 10:20 AM
cougar's Avatar
Thanks!
I want to avoid using electric pumps because I don't want to rely on an electrical system. But the 4601 is at the top of my options list.
I'm also researching information on using an air starter.
I considered installing larger fuel line was part of the pump deal any way. So I didn't mention it.
GIT-R-DONE
Aug 24, 2011 10:27 PM
rustydeeretech
Dec 26, 2010 12:35 AM
BurrisWill
May 29, 2009 12:58 AM
CTD99
13
Aug 23, 2005 10:55 PM
Dieseldude4x4
Apr 3, 2004 06:24 PM
