swap question auto to manual, with a twist
Old Dec 14, 2009 | 01:02 AM
mullishacrew's Avatar
hey, so i can get my hands on a spicer 5 speed transmission, model # is Cm 5252-A i know they get them in the freightliners like the fl70's whitch have our 5.9 engines. so my question is can or has anyone swapped a spicer 5 speed into our trucks? with the divorced transfercase? and i can get all the bellhousing and everything, just need the adpater, it's hydraulic push type lever on the bellhousing.
Old Dec 14, 2009 | 02:52 PM
anyonnee know anything on this? it's comming out of a cab over international, dident get the model number or year sorry
Old Dec 14, 2009 | 03:46 PM
Why do you want that heavy balky thing? It does not even have overdrive.
Old Dec 14, 2009 | 09:11 PM
JustRamIt91's Avatar
They shift like crap also, a fuller trans is even worse. It will give you that big rig feel but with those long throws idk if you'd have enough room in our cabs. My knuckles it the dash when i go into first.
Old Dec 16, 2009 | 05:27 PM
Onemoparnut's Avatar
There is a guy by mt that has either an 13 or 18 speed in his 250 4x4 looks like 92 or 93 nice truck just dont see the point of all that trans. What do you need to pull that you cant pull now.
Old Dec 16, 2009 | 08:12 PM
i dont know i have blown up 2 autos in the last year, and this transmission came up and i figure dit would be a neat swap, not really any purpose for it, just something different, but i did not realize it was that bad of a transmission, i think ill end up with gettin another transmission like ATS or something like that
Old Dec 16, 2009 | 08:38 PM
freight train's Avatar
One word: NV4500!!!!!
I went from a Getbag and I wish I would have done it yrs ago.
Old Dec 16, 2009 | 10:35 PM
Falcon1's Avatar
I'm trying to swap my auto. I may have a doner 98. Will the clutch peddle and linkage and all work with my truck I'm trying to swap my auto out?
Old Dec 17, 2009 | 12:09 PM
Machinos's Avatar
It's not that they're bad transmissions, in fact they'll probably last way longer than any stock transmission from a Dodge, but I wouldn't use one unless you want it for heavy duty kind of work. I'm still collecting parts for a swap on my truck, but I'm building it for lots of long-distance heavy towing.
The first time I drove one I couldn't figure out why I kept grinding the gears so much, and it turns out that the synchros aren't really the same as the ones on passenger vehicles... you have to hold the shifter lightly against the gear for half a second or so before it'll go. So if you're racing it or something you definitely don't want to go that route.
I can't imagine putting a 13/18 speed in one, those things weigh close to half a ton!
Old Dec 17, 2009 | 03:40 PM
:-D i agree with machinos, he explained it better than i could. They the laid back, easy going, but will tow a house kind of transmissions.
As for the bigger transmissions i wouldn't put anything but an Eaton fuller 6 because the the gears are spaced out and would be better for our small trucks. The tight gear ratios of other would suck, or you might not have a good gear in the rear to jump a gear or two.
Old Dec 17, 2009 | 04:45 PM
NoFrills's Avatar
i am gathering parts to put a fuller 6 speed in my crew cab i have read that the sae 2 bellhousing that med duty truck transmissions use will not fit under a stock 1st gen firewall so i made a adaptor to use a getrag bell and am yet to figure out if its going to use the fullers 1 3/4" input or get turned down to a 1 1/4
Old Dec 17, 2009 | 04:46 PM
You should be able to get a different clutch to match, right?
Old Dec 17, 2009 | 05:35 PM
NoFrills's Avatar
I emailed southbend and they told me that they can make me a push type clutch to fit in the getrag bell with a 1 3/4 input I need to call one day and actually talk to them becouse I don't really know what kind of throwout bearing you would use the collor is real big like over 2"
Old Dec 18, 2009 | 03:28 PM
Use the one for that particular trans....right? Then get a custom fork made, how ever you decide how to actuate it. I have a circle track and 4wheel parts book they have all sorts of hydraulic slave cylinders, i'll see if anything looks like it will work. Can you get pictures of all this? maybe even a measurement of the distance between where the clutch will sit and the rear of the housing.
SilverSootXpres
Jun 19, 2009 11:48 AM
Billut
Dec 11, 2008 09:40 AM
2500Ram
Apr 1, 2006 09:32 AM
merrillr4
Mar 20, 2006 05:54 PM
ezdemon72
14
Jul 29, 2005 10:05 AM
