Swap
Old Mar 1, 2016 | 12:08 PM
dynaglide's Avatar
Swap
Hi everyone, has anyone swapped a engine out of an 89 to a 92? If so what problems did you run into?
Old Mar 1, 2016 | 03:25 PM
Vader93's Avatar
Well in sure we'll be adding alot to this post as in currently swapping a 91 into a 93.
Old Mar 1, 2016 | 03:37 PM
dynaglide's Avatar
That should be a lot easier. The wiring should all be the same especially if you're going to and from the same transmission. The main changes to these trucks were between 89-90.5. I all ready have mine swapped and driving but i'm running into all kinds of electrical gremlins most stuff just isn't working. The weirdest part is sometimes they will work intermittently.
Old Mar 1, 2016 | 04:23 PM
mknittle's Avatar
I think that's 89 to 91.5.
Old Mar 1, 2016 | 08:41 PM
Vader93's Avatar
Yeah, I'm going from a non ic truck with no computer to an intercooled truck with computer. I plan on running the intercooler on this motor that i picked up with my ve pump a while back
Old Mar 1, 2016 | 08:57 PM
freight train's Avatar
I might be able to shed some light for ya. I swapped a 90 Non I/C motor into a 92 RC and used all 1992 harness's to use a PCM for the gauges and a factory tach. I believe I have some of the swapped parts shown in the build thread.
Very subtle differences. You need to swap a 1992 damper, crank sensor, and intake plate for air temp sensor. The I/P's are the same EXCEPT for the KSB's. The non I/C has its wax pallet inside the KSB while the I/C versions use an external. That's what controls timing in the pump depending on temperature. I simply ran a jumper wire down from the FSS to power it.
Old Mar 1, 2016 | 10:49 PM
Vader93's Avatar
Very good info sir, thank you
Old Mar 1, 2016 | 11:04 PM
I have to correct a couple small things....the IP's are a little different. There is the KSB difference as mentioned, but the delivery valve housings are longer on a Non-IC motor, compared to the IC units...so the injector lines will need to be swapped as well. I do not believe the Non-IC injector lines will clear the IC motor intake plate and the associated hardware. Also internally the re is some slight differences...but not enough to make a difference in the running of the motor.
Old Mar 1, 2016 | 11:08 PM
Vader93's Avatar
I'm running a non intercooled pump on my intercooled motor. All i did was swap the pump out. Didn't change anything else. When i had it rebuilt i sent an intercooled ksb with the pump so they swapped it out while rebuilding. I might be one of the lucky ones though.
Old Mar 1, 2016 | 11:41 PM
Yeah you can probably get away with going with longer DV from a Non-IC motor onto a IC injector lines.....just pushes back a bit. Might be tougher going the other way though?
Old Mar 1, 2016 | 11:46 PM
Vader93's Avatar
Very true. You've got me wondering T, would the difference on the internals of the 2 pumps contribute to my relentless haze?
Old Mar 2, 2016 | 05:42 PM
Cows I didn't mention the bigger DV's in the pumps as he wasn't swapping pumps. He asked what was needed to swap the complete motors from a 89-mid 91 into a 92/93 truck. DV's don't need to be changed since he isn't swapping one pump to another engine.
Also to swap the intake plates a slight adjustment to #1 line was required to miss the sensor. A picture of this plate installed on the 90 motor is shown on page #2 on my build thread. Now all lines and plate sensor placement should be the same but slight modifications may be needed if previous owners messed with the lines or something similar.
https://www.dieseltruckresource.com/...-279787/page2/
bigwheels94
Jul 11, 2008 03:10 PM
Treangen
63
Jul 7, 2008 07:42 PM
Superduty12v
Feb 20, 2003 03:44 AM
Wilber1
Dec 9, 2002 01:07 AM
14
Oct 30, 2002 06:33 PM
