Stupid question of the day
Any guesses on my Dana 70 gear ratio? I know it's not 410, but can't remember if it's 373 or 355. I guessed 373 when I bought a new speedo gear for the gear vendors, but can't drive it yet because the speedo cable is wrong, and I don't want to dump $40 bucks worth of Mopar Synthetic gear oil out the speedo hole!
look on the rearend it is usually stamped on them some were. if not try the jacking up one side with the truck in N then count the roations of the drive shaft with one rotation of the tire.
I don't believe you could get 3.73 gears at that time, if it was an auto from the factory it is most likely 3.08, if it was a getrag it is most likely 3.53, however if it was a 1-ton than either could be 4.10's. I would be 95% positive you have 3.53 gears.
And you call that a stupid question?!, just be patient and watch me. I'll show you how it's done.
This is my first diesel, and I have to keep going to the definitions thread just to follow along.
I'm making a list, I'll show you professional grade stupid!
Originally Posted by mhuppertz
Thanks for your support, but you have to admit, asking others specifics about my truck is pretty stupid!
Originally Posted by Geico266
Na. Try searching your question before you ask and if you can't find a satisfactory answer we'll make one up for ya.
