Stock Boost On 92 Ic
gomerpile- you also have an auto, which will not load the engine near as much. My mom's 92 has about the same set up as mine had when I got it (stock injectors, about 100mm/stroke fuel, etc), and I could get to 24psi boost; she tops out at 21psi.
Daniel
Daniel
I'm hitting about 26-27 psi max, not sure what it was stock, just put the boost gauge in a couple days ago...this is on a '92 IC with mild injectors, fuel pin, BHAF, 4" turbo back exhaust, pump cranked up, timing bumped. 16CM housing coming soon...
Hammer Down
Yep I'm right at the same place maybe a lb or so more but not by much.
I think these things came with different pump settings. Not by much but they must have been tuned differently off the line.
97dodgeram2500
11-01-2009 11:51 PM
vwjunkie53
19
11-09-2007 02:27 PM
Bobcat698
18
10-22-2005 12:27 PM
sammy340
04-05-2005 03:55 PM
