Smooth ride in a 1st. Gen.
The 4WD shop I have been working with became a dealer for these about a year ago. He has sets on all of his trucks, as well as the employees trucks and soon to be on my CTD. The effectively remove axle wrap and have claims to reduce many other problems. Every customer have (dozens) has been very happy. Mine are being put on today so I don't have any impressions yet.
http://www.activesuspension.com/
My reason for installing a limiting strap is to protect the air bag in the event the truck was lifted from the body and not the axle, where it could possibly damage the bag from over-extension.
Since my truck never goes off road or is harshly abused I would only install them to protect the bag if some tow truck driver thought he could lift my truck.
Jim
Jim
One very common situation, that probably all of our trucks will experience numerous times, is being lifted with a frame-hoist.
Even something so basic as an oil-change, or tire change, not done in the driveway at home, can subject the truck to being lifted by the frame, with the wheels left hanging, and, without limiting straps, the weight of the axles hanging on the rubber bags.
Another point to consider:
When air-bags are first purchased, BUY A SPARE BAG.
Every day I see air-bags that have been destroyed by steel-belted radial tire failures.
The air-bags are right next to the tires.
When a tire sheds it's steel belt, it comes swinging around, like a big weedeater string, taking everything in it's path; a soft-sided air-bag is no match.
This is no real problem on big trucks, as the bags are pretty much standard, simple to install, and available at any decent auto-parts; but, I would imagine the bags for these smaller trucks would be somewhat harder to find, on short notice.
Prior to the install, the ride was HARSH - almost like the Previous Owner had welded the spring pack together!
It WAS worth the effort - and every penny! The only problem installing them was the typical rusted fast and frozen bolts. My frame was slightly pulled together (about 1/2") when I transferred the flatbed from my 76 gasser, but a slight nudge with a porto-power did the trick. I still have not replaced the channel bumper which I welded to the flatbed back in 1980 and which was in the way of the new trailer hitch receiver, but that will come.
I also want to put an onboard controller/compresser/gauge so I can tailer the ride to the load. That would be a lot more cool than having to get out and use an air hose and gauge to adjust things.
Now, the ride is honest - the bumps are still in the road, but no longer do you feel like you're getting hit with a 2x4. Having installed the bags on all four corners, I would have to say that when I get my next (?) 1st Gen truck, I will look for another set of Kelderman Bags - and pay full retail if I have to. (I lucked out and got my set used and at a great fair price from Swampthang)
Next time I have my truck in Oregon
I'll give you a call for a ride.The limiting strap and spare air bag are both good suggestions - but at this point if I'm not going cross country I don't even carry a spare tire! I figure that I have a couple of those on the ground at the rear.
What I'd like to come up with now is a good beefy torsion bar/anti sway bar for the rear end. At times I am loaded top heavy, and it occurs to me that it might help the lean on the corners. This isn't an air bag issue, it was just as true before I put'em on.
that's what i like to hear , a plan that comes together. i realize short of building a new rig a first gen is allways going to be a pickup that is alittle on the rough ride side of things but as you said taking the edge off would be nice. thanks for the comeback. come on out to oregon always room on a 40 acre farm for a rig or two.
Is removal of 2,3, and 6 the way you'd go again? I didn't see a follow up post to this thread after the I more planned to remove so I thought I'd check in here before starting a new thread.
(I've followed the spring tips and custom leaf set plans threads but for now I'm going the removal route to start. Thanks for the invaluable info on the starting point you've already provided on this route!
jims set up is great,for those of you wanting traction control since you are messing with the spring pack anyways coudnt you cut the back of some of the leafs off while retaining the fronts ala mopar super stock spring? I have the kelderman system on my truck rides great , butwith aload the spring is overtaxed because the airbag is at the end of the leaf. gonna add air bags over the axel and have the best of both worlds.
goodeyesniper75
Apr 5, 2007 06:14 PM
wood_n_soldier
Jul 23, 2004 11:20 AM
