Sensor?
Sensor?
Where is the temperature sensor located for the gauge on the gauge cluster. Mine stays on Cold and then goes all the way to hot.. and then somewhere in the middle before it goes back to cold.
Is it the same as the ambient sensor for the grids?
I agree with 93flatbed, check your coolant. If you have just added coolant, you might have an airlock. Loosen the plug in the front of the head beside the engine lift to bleed the air out and top off with coolant again.
I will have to check that, I'm pretty sure the sensor is toasted though. Getting some quirky reading from it
http://www.genosgarage.com/CUMMINS-3...tinfo/3920363/
Might just be a bad connection I think that the wire just slips on a post on the sensor. Take the end off the wire and put an eyelet on it and attach it to the sensor with a small nut.
tyssniffen
02-11-2006 01:28 PM
Booost Almighty
01-01-2006 01:41 PM
