re routing fuel return line
Old Sep 22, 2008 | 07:07 AM
Exekiel69's Avatar
I was thinking to T the fuel return line on the suction side of the pump (I have a electric pump on the frame close to the tanks) so it would reuse the fuel not just pour it back on the tank, is this something that will create a future problem?
Thank You.
Old Sep 22, 2008 | 10:45 AM
brainfade's Avatar
I wouldn't short circuit the return. Reason is that the fuel helps cool the pump and the return line fuel is hotter than the fuel in the tank. Might be OK for a drag or pulling truck but I don't think it will help on a road truck.
Old Sep 22, 2008 | 11:50 AM
JD730's Avatar
Thats a really bad idea. There's no way to get rid of excess air and self bleed the fuel system without a dedicated return. There's also the potential that an air leak in your return system could introduce air into your main fuel system causing all kinds of running problems with foamy fuel.
Old Sep 22, 2008 | 06:26 PM
Exekiel69's Avatar
Thank You guys, that is why I asked here first. I guess is a no go.
Question
I understand the air leak is a possibility now the fuel temp well for some people using alternative fuels is actually a good thing to have the fuel at a higher temperature so that I don't see it as a problem now how can the fuel foam?
Scotts_D250
Jul 10, 2011 01:05 AM
ctd4stan
May 18, 2009 02:56 PM
Tiara3100
Jan 14, 2008 10:06 AM
loggertruck
Nov 5, 2007 04:36 PM
ldperrine
Jan 7, 2006 01:47 AM
