Fass Install - Fuel Line Routing
Old 11-04-2007, 06:18 PM
loggertruck's Avatar
My fuel pressure gauge starting showing some pretty bad numbers on my stock fuel system. I decided to go with the FASS and mounted it according to the directions, see picture. The pre-filter and new fuel line from the tank are all plumbed to the FASS. See picture.
Where in the world is everyone running the new fuel line from the FASS to the fuel filter?
I have seen a few pictures of other FASS installs and it looks like everyone is running the line thru the tunnel between the cab and box, over the frame, over the tank and then WHERE? Everything I have tried so far looks ugly.
Any help here would be greatly appreciated. Any pictures?
Thanks,
J
Attached Thumbnails Fass Install - Fuel Line Routing-img_1878a.jpg   Fass Install - Fuel Line Routing-img_1886a.jpg   Fass Install - Fuel Line Routing-img_1890a.jpg   Fass Install - Fuel Line Routing-img_1892a.jpg   Fass Install - Fuel Line Routing-img_1893a.jpg
Old 11-05-2007, 03:58 PM
Tocapet's Avatar
Mine is mounted exactly where yours is. From there I went with the line in the same direction as your arrow, then I ran it along the frame and tie-wrapped it to the fuel return line every few inches. When I got up to where the old steel fuel line went thru a plastic block, I ran mine thru that block that the factory hose went thru and then up to the top of the fuel filter. I tie-wrapped it to something up there, don't remember and used a fitting that eliminates the banjo bolts. Works fine. According to your pictures, you're running it too far over towards the right side. Just make a turn with it as soon as you get over the top of the frame.
Old 11-05-2007, 04:14 PM
Ed ke6bnl's Avatar
those running the FASS with the filters are you bypassing the original fuel filter.?? Ed ke6bnl
Old 11-05-2007, 04:36 PM
bnold's Avatar
Yes (10 char limit)
user name
07-17-2012 06:12 PM
clowndodge01
10-30-2010 09:04 PM
Exekiel69
09-22-2008 06:26 PM
DarrinGT
01-30-2008 12:13 PM
ldperrine
01-07-2006 01:47 AM
Quick Reply: Fass Install - Fuel Line Routing
